Hydrocarbon emmisions help!!
Old Oct 5, 2001 | 11:11 AM
Fastcamaro87's Avatar
Ok heres the story, i took my car for inspection and the only part of the emmisions test that it failed was the :
HC ppm reading at idle which was 338 and the limit allowed was 220 .
does anyone know how i can get this reading down? i am going to change the plugs and all my other ignition components are new so they are not likely the problem, any tips or tricks to get this number down to an acceptable level? even if its only gonna last long enough to pass the test, cause thats all i really need to do. thanks in advance
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Oct 5, 2001 | 11:23 AM
nblanchard's Avatar
Have you changed the PCV valve lately? Try cleaning out your throttle body with a spray TB cleaner.
Old Oct 5, 2001 | 06:09 PM
JB Camaro SS's Avatar
Retard your timing about 4 degrees, this will bring your HC down.
Mark A Shields
May 30, 2001 08:17 AM
BrianB
May 21, 2001 10:29 PM
88transam5.0
May 3, 2001 12:34 AM
Ward
Oct 1, 2000 02:36 PM
