FPR removal? Vader?
Old Oct 6, 2001 | 03:02 PM
87_350_Z's Avatar
FPR removal? Vader?
I've got my fuel rails all pulled apart
to do the AFPR modification but cant
figure out how to get the regulator
off. It looks like there is enough flex
in the fuel line to let it come off but
I cant get it off. Is there something
holding it on the rail that I'm not
seeing? Do I need to disassemble the
regulator first? Or do I just need to
quit being a puss and pry it off?
THX,
Jack
BTW, does anyone have a source for the
.310 steel ball I'm supposed to use
in the AFPR mod?
'87 Z28 350 4bolt
CompCams Roller everything, TPI
conv in progress.
Old Oct 6, 2001 | 04:39 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
There sgould be some tamperproof torx bits going around the reg. You need to remove those and put the new regulator on. The fuel rails DON'T come apart.
Old Oct 6, 2001 | 05:15 PM
87tpi420's Avatar
what he said. some have tamper proof torx bits and some dont. (mine did not) remove the screws and pull the cover/cap off.
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake hooker long tube headers mufflex 4"exhaust accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
Old Oct 6, 2001 | 08:28 PM
87_350_Z's Avatar
Thanks for the advice but that's not the problem. I know how to get the FPR
apart. I just cant seem to get the
regulator base off of the right side
fuel rail. I'm sure it just pulls off
after you remove the retaining bracket
and the long screw underneath it
but it sure is stubborn! And I'm afraid to
force it. I'm just looking for confirmation
that it comes off this way before I get
horsy with it.
Jack
'87 Z28 350 4bolt
conv in progress.
Old Oct 6, 2001 | 11:09 PM
87_350_Z's Avatar
I got it off.
THX,
Jack
'87 Z28 350 4bolt
conv in progress.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Strick1
Sep 4, 2015 07:11 AM
