What kind of hp from this build?
Old Apr 24, 2008 | 02:45 PM
PatrickL's Avatar
Car: 91 RS
Engine: 305 TBI, Edelbrock TES
Axle/Gears: 3.73 10-bolt Auburn Posi
I'm changing over from TBI to TPI, what kind of HP can I expect from a 305 with:
Edelbrock TES
American Thunder Cat-back
No Cat
S/R Torquer 305 Heads
Stock TPI setup (except AFPR), speed density set up
'95 LT-1 Camshaft
I'm hoping for 250 hp net at the flywheel (20 over the G92's in '91). Is this reasonable? I already do my own tuning with the TBI, and will tune it with the TPI as well.
I'm also running a T-5 and a 3.73 gear - what 1/4 ET could I expect?
Any speculation is welcome.
Old Apr 25, 2008 | 12:06 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: What kind of hp from this build?
250 at the flywheel sound about right. That would be about 210 at the wheels. 1/4 mile ET would be high 14's at 93 MPH or so if you can shift and at a sea level track.
69GTOby
Apr 18, 2016 02:34 PM
jbates346
Oct 21, 2015 01:50 PM
Jorlain
Oct 8, 2015 01:57 AM
R13_Braz
Sep 18, 2015 05:00 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
