Help!!!! Big POP!!! whole car shut off!!L@@K Pics inside of what happened!!!AAHH!!!!
Old Oct 10, 2001 | 06:17 AM
JucinGTA's Avatar
Ok I get up at 5 in the morning to drop my car off at the dealership, to get the door repainted. I dont even drive thing really anymore, so I havent drivin it in about 2 weeks, cause its sold. Well yesterday I was takin some nitrous stuff off and I forgot to move the harness. I drive about 2 miles to the Gas Station, right when I pull in, POP!!!!! everything goes out!!!!! No headlights no nothin, the headlights didnt even go down. The only thing that works is the interior lights???No dash no lights when I turn the key foward, NOTHING!!!!I checked the fuses too, they are all good!!! I think its my fusable link??? Where is it located so I can check it?
Heres a pic, this is right by the heater box, kinda a goofy angle, but if you dont notice it see the dipstick for the trans. Also the red wire I melted see how it has a snap plug to the right!!!!
[This message has been edited by JucinGTA (edited October 10, 2001).]
Old Oct 10, 2001 | 06:24 AM
JucinGTA's Avatar
Heres a closer pic!!!
Im goin back to bed cause Im furious!!!! I hope my ThirdGen Brothers know the answer
Old Oct 10, 2001 | 09:57 AM
JucinGTA's Avatar
ttt
Old Oct 10, 2001 | 10:05 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Figure out what else is on that circuit; you have a short that will need to be located and fixed. Then you fix that wire. Then you're good to go again.
The fusible link is part of the bundle of wires that go to the starter (and other things)
jmd
1986 SS with...
86LB9 TPI atop the original L69, Hooker emissions legal PN 2050 headers, stock L69 cat (yes, a real one), hydraulic clutch T5, Energizer 272 cam, chargedair.com fan, Global West CNR-88-C negative roll kit, 89 Iroc front springs, CC635 Moog rear springs and a whole bunch of other fun stuff
Old Oct 10, 2001 | 10:16 AM
JucinGTA's Avatar
I located the short, its where the wire is cut up!!! It fell on the header and I had to pull it off cause it was melted to it. Still I have nothing but the interior lights. So it has to be the fusable link right?
Old Oct 10, 2001 | 10:54 AM
Desert86Roc's Avatar
Depending on what that wire went to, you could have fried any number of components. First thing you need to check is all the fuses under the dash. Then go from there.
Old Oct 10, 2001 | 11:03 AM
JucinGTA's Avatar
I already checked all the fuses as I said in the previous post.
Old Oct 10, 2001 | 11:06 AM
u r sofa king we tah did's Avatar
depending on what that hot wire went to, your ecm might be and *probably* is gone. since you have interior lights then your still getting power somewhere.
Old Oct 10, 2001 | 11:18 AM
JucinGTA's Avatar
Hey sofa I was just thinking that, now if that were true is it just the chip that goes bad or the whole computer?
Were the wire was fried I just cut it off and replaced it, still nothing!!!
Old Oct 10, 2001 | 11:30 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Check your in-line fuses near the battery. Not all the fuses are under the drivers side.
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
Old Oct 10, 2001 | 12:20 PM
hotpowerandperf's Avatar
The wire you show appears to be the AC blower main power feed to the relay. This wire originates at the starter on the large lug. Goes through a fusible link(this is attached to the starter lug) and becomes a branch(the other branch(es) go to the inside of the car. You should only need to replace the fusible link. Remove the wires from the large lug of the starter. Inspect them for melting, seperation or if you see nothing continuity. The loud POP you describe leads me to believe that the fusible link will be totally gone.
John
Heart of Texas Power and Performance
Old Oct 10, 2001 | 02:40 PM
JucinGTA's Avatar
How do you actually tell if a fuseable link is bad? How is it replaced?
Old Oct 10, 2001 | 02:42 PM
JucinGTA's Avatar
Oh ya by the way I had the starter wires off and they looked fine, when I was lookin at the links, how n the hell do you open them up or inspect them?
By the way guys thanks for helping me out, I need this **** to be running by tonight.
Old Oct 10, 2001 | 03:44 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
the only way to open that up is by destroying it in the process.it sounds to me like the fusable link if it is there is one way of checking it.take a test light to the starter terminals,since that is a series circut one leg will theoretically kll the whole set.(kina like christmas lights take one bulb out and all are dead same principle).
Old Oct 10, 2001 | 04:01 PM
JucinGTA's Avatar
Should I do this with the ignition on or off?? So what your saying is just stick a testlight on the bigger terminal and if it doesnt light that means its bad? Sorry for so many ?s I havent done this ever!!!
Old Oct 10, 2001 | 04:50 PM
JucinGTA's Avatar
Anyone?
Old Oct 10, 2001 | 09:25 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
A bad fuseable link will either stretch when you pull on both ends or it will be squishy (it's an industrial term) when you mash it between your fingers. Take your multi meter and test continuity across the link my sticking the wires with a safety pin. Hope this helps.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Oct 10, 2001 | 09:36 PM
breathment's Avatar
i always thought fusable links just kinda melted.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Oct 10, 2001 | 10:42 PM
JucinGTA's Avatar
Thanks Ill try that!!!!
Old Oct 11, 2001 | 11:42 AM
JucinGTA's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Rob P:
</font>
Man you are the $$$$$ I didnt even notice it until I looked closer and saw the wire burned inside you could just pull it apart, I will post a pic later!!! Thanks guys you helped alot!!!!
RazorN8
Jan 7, 2022 11:44 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Fronzizzle
Aug 9, 2015 01:15 PM
