Finishing up MAF>SD conversion, couple of quick ?'s.
Old Oct 11, 2001 | 11:13 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I am just about finished with my conversion all I need to do now is re-pin my ECM connectors.
Question I have is about the ESC and the MAF relays. I can just pull those 3 parts from the car now, right?
Will I be able to use any of those wires from any of those relays for my MAP sensor, or should I just run new wires to the ECM.
Thanks,
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Oct 11, 2001 | 08:44 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Yes, you can just get rid of the ESC and MAF relays.
You won't be able to use those wires. Besides, all you really need to do is run 3 new wires from the computer to the MAP sensor.
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
chazman
Aug 22, 2015 02:01 PM
Linson
Aug 21, 2015 02:12 PM
