2nd gen lt1 intake on 383 gm crate engine
Old Oct 10, 2001 | 04:13 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
what do you guys think of this combo?gm crate 383,lt4 intake,fastburn heads and an lt4 hot cam.do you think this engine is reliable?for me it's definately cost efficient.just curious to know if anyone has heard anything on this engine and the specs(2 or 4 bolt,nod.iron or steel crank,PM rods?etc.)
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,slp 3in. catbcak,a/c delete.
SHE IS GONE BUT I KNOW THE GUY WILL GIVE HER A GOOD HOME.
best e/t:
3653lbs./full tank+ driver.
14.10@96.53mph 2.01 60'
Old Oct 10, 2001 | 06:07 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
You sure the LT4 intake will bolt up? For some reason (I could be wrong) i remember or at least thought i remembered someone claiming differences in the LT4 heads. Makeing way for a difference in the way the LT4 manifold lines up or something along those lines. Again i could be wrong.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Oct 10, 2001 | 07:44 PM
irocbsa's Avatar
I don't think that intake is gonna bolt up, unless it has the Vortec bolt pattern. I really don't know LT1s or LT4s. Do some research and find out, then post back.
bsa
Old Oct 10, 2001 | 08:38 PM
Tas's Avatar
Tas
the fast burn ports are higher than normal. Why not get a Ram Jet intake?
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
Old Oct 11, 2001 | 07:27 PM
PETE's Avatar
Car: 1989 TTA #1240
Transmission: 2004r
i figured use the short runner design on the 383 because those heads are like 210cc's and the intake i can get for nothing and the heads for like $960(last time i checked),and with all the guess work taken out of it now(see lt1 intake on a 1st gen sbc post)it would seem to be a nice package.the ram jet is nice but too many differences(ls1 type tb/iat/tps/etc).
best e/t:
Old Oct 12, 2001 | 12:07 AM
airdeano's Avatar
applying the lt1/4 intakes can be done on gen
1 engines. be prepared to modify and have a
good machine shop. see the link below:
http://web.camaross.com/bb/Forum12/HTML/011509.html
lt1 383 are done daily. pretty good results
a lil confusing some arent dialed in and
gripin' about "its not what they thought"
the fast burns would be a good choice, but
what are your intentions? maybe some afr190-195
heads unless you like the titanium vales and 6400rpm
so if your looking for that rpm, that bottom
end isnt ready.. your gunna need some crankshaft
and lots of work.
some good ideas...
airdeano
[This message has been edited by airdeano (edited October 11, 2001).]
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
