Setting timing with painless harness...
Old Oct 10, 2001 | 10:02 PM
Ehelmsin's Avatar
My buddy has a '77 Camaro with an '87 Tpi in it. He used a pianless wiring harness to install it. How can we figure out which wire needs to be disconceted to set the timing? The tech artical defines it by color, but painless wires are all black with writing on them. WHat is the correct name of this wire, or where does it lead to?
Ps. The engine is the GMPP 350 h.o. with 300 horse power (from befor they started using the vortec heads.) its one step down from the ZZ4. What would be a good place to set the timing at?
'89 Iroc-Z
350 TPI
Some free mods-
otherwise stock.
14.92 @ 92.73
Old Oct 10, 2001 | 10:15 PM
Guest
Guest
Posts: n/a
<font face="Verdana, Arial" size="2">Originally posted by Ehelmsin:
</font>
What???? How old is this harness? All the ones I have seen are color coded just like the factory stuff. I can see having a hard time finding the right wire if thats the case.
It runs from the distributor to a specific pin on the ecm. I dont have the information handy but can get it if someone else doesnt have it for you. Its a single wire, and should have a weatherpack connector about 6-8" from the ecm if its anything like the painless harness I have.
Old Oct 10, 2001 | 10:53 PM
Ehelmsin's Avatar
The wires have writing on them like "battery" or "injector 1" so the aren't completely black. Do you know where it runs to on the distributor? thanks
Old Oct 11, 2001 | 08:20 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
If they used GM terminology, it may be labled as EST Bypass, or similar.
Old Oct 11, 2001 | 08:37 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Like Mike said, it's prolly called EST bypass or something, and it will be one of the 4 wires that run into the distributor (on the computer harness obviously, not the power/tach wires, etc)
Old Oct 12, 2001 | 01:21 AM
airdeano's Avatar
on our harnesses we use a brown wire with the
single weatherpak connector. and its usually
3-5" from the distributor. all black??
call 'em.. its call the EST BYPASS.
electronic spark timing bypass
set between 6-10* btc
hope you get your answers...
airdeano
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Caspar
Jun 19, 2016 11:19 PM
squiggy2
Aug 9, 2015 09:30 PM
