Any use a ramjet cam in a 350 TPI motor
Old Oct 10, 2001 | 12:52 AM
89rsvert's Avatar
Car: 1989 Camaro convertible
I am going through my L98 I just bought and I am using the tpi system for now. I am wondering if anyone has used the ramjet motor's roller cam. the specs are I: 0.431 and E:0.451 lift. The duration is I:196, E:207 and the lobe seperation is 109. I plan to swap out to the ramjet injection system within a year or two, and install the vortec heads then to, but if I could do that cam for now, I wouldn't have to mess with the short block. Would it hurt or help the L98? Any advice would be a great help.
89'Camaro Convertible,96'firebird wheels,79'Z28 hood scoop,350 tuned port injection engine, 3.27 posi disc brake rearend,36mm front sway bar, 24mm rear bar, all donated by a 89'Formula 350, Poly sway bar bushings and end links, Dark yellow green paint from Bonnevilles, tan Mr. Mikes leather interior,Macewen white face gauges.
Dreaming of a RamJet 350,
Open element
Jet fan switch
180 degree thermostat
Flowmaster cat back system
2nd place is always the first loser!
Old Oct 10, 2001 | 01:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
That'd be a good cam for a stock or mild 305, but too small for a 350, in my opinion. I'm surprised they get that much power from the RamJet with that cam.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 12, 2001 | 05:53 PM
Drakar's Avatar
I think your lossing alot by switching as I think an L98 cam is 207/213, so you would be lossing. I would say it is a waste of time, plus I think the computer would have trouble with the lobe.
1989 Trans Am GTA - Flame Red Metallic, L98 5.7L TPI, TH700-R4, T-Tops, 3.27, 9-bolt rear, dual cat
- K&N Air & Oil Filter
- Dynomax muffler
1992 Camaro RS - Hawaiian Orchid, LO3 5.0L TBI, T-5, T-Tops, 3.08, 10-bolt rear - Sold
- L69 Dual Snorkel
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
squiggy2
Aug 9, 2015 09:30 PM
