How do I bump my timing up and what are the pros and cons????
Old Oct 13, 2001 | 11:25 AM
IROCME's Avatar
Car: 1986 IROCZ
Engine: LB9....rebuilding coming soon
Transmission: rebuilt 700R4
On a 86 IROCZ 5.0TPI what difference if any would there be??
86 IROCZ 5.0 TPI/"new" 700R4 auto with transgo shift kit and vette servo,canary yellow,t-tops,radar detector,tan interior,hidden antenna,tinted windows,taillight blackouts,front end bra,k&n air filters,no cat,full 3" racing exhaust with 40 series flowmaster and chrome tips,2:73 posi rear(soon to be 3:42 or 3:73 posi),1989 IROCZ 16*8 polished aluminum rims
Old Oct 13, 2001 | 11:35 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Increasing ignition timing can have a positive effect on performance. My suggestion is to be conservative. Factory specs call for 6 degs btdc. Start by increasing timing to 8 degs btdc then 10 degs. Just remember to use Premium fuel and listen for any sign of detonation. Good Luck!
www.geocities.com/dzperf
D&Z Performance
"Putting Power to the Pavement"
Old Oct 13, 2001 | 01:18 PM
IROCME's Avatar
Car: 1986 IROCZ
Ok,but how do I physically bump up my timing??
Old Oct 13, 2001 | 01:44 PM
91'firebrd's Avatar
Loosen the bolt that holds the distributor from turning and rotate it the opposite way that the rotor spins. Mark it were it is before you start and you will be doing it in about 1/8" increments. Ideally you won't notice any difference but will be a tenth or two faster in the quarter mile.
Old Oct 14, 2001 | 07:56 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
To set the timing, you must disconnect the est wire. If you are unfamiliar with this wire, it's a brown and black striped wire that you will find by the firewall on the passenger side. Once you find the wire, here's what to do:
1. Start car the disconnect wire. The motor may die out so have someone feather the throttle until it stabilizes.
2.Check set timing to desired position.
3.Turn ignition off, reconnect wire, disconnect negative battery cable for at least 30 seconds.
4. Reconnect negative cable.
D&Z Performance
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
