16 ohm injectors.
Old Apr 29, 2008 | 06:54 PM
jcp74's Avatar
16 ohm injectors.
Ok. My injectors are junk. my question now is, Do I need 16 ohm injectors?
I went to fiveomotorsports and they have replacements but they are rated at 14.5 ohms.
Would I have to modify anything if I used the 14 ohm injectors. the flow rate is the same 22 lbs. My mechanic is convinced I need 16 ohm injectors.
If I do, the stock injectors are too expensive and the car will have a for sale sign on it this week! Thanks for your help once again!
Old Apr 29, 2008 | 10:07 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: 16 ohm injectors.
That should be fine. They are still "high impedance" injectors.
Old Apr 29, 2008 | 11:36 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
five o motor sports beware... they sell rebuilts as new and charge through the nose.. they say they are new car take outs.. if they were in a new car they are used.. the 22 was only used in fords up to 2003... why were they taken out. he sends them in a baggie.. shop around.. he also ripped a friend and would not honor a return when the new injectors were all full of grease.
Fanatic1074
Oct 3, 2022 05:57 AM
Elephantismo
Feb 13, 2019 12:51 AM
lewandom
Oct 1, 2015 08:15 AM
dusterbd
Sep 29, 2015 08:40 AM
ironbmt
Sep 27, 2015 06:00 AM
