Help w/ shift light!!
Old Oct 21, 2001 | 02:30 AM
chevyboy07 91's Avatar
I have a Proform shift light I'm trying to install and have a couple questions. The instructions say RED=12V ignition switch, Black=good engine ground, Green=Tach terminal(for GM, HEI, MSD) or to coil negative (for standard ignition).
Where is the best/easiest place for my RED wire and where the heck does the green wire actually go? I didn't know we had a "tach terminal" on our cars. Can someone please fill me in. P>S...I posted in electronics as well.
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
Old Oct 21, 2001 | 08:07 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
The tach terminal is on the distributer cap. Look at the cap where the harness plugs in to the bottom side of the distributer cap.There is a terninal connection marked TACH. You can run you red wire to the fuse box under the driver side of the dash.
86 IROC T5
MSD 6A
Summit cam
Flowmaster
AFPR
Lowered 1.5"
My own prom
LittleFranks
Sep 17, 2015 12:22 PM
tnrednneck
Aug 13, 2015 08:57 AM
dhonda200
Aug 11, 2015 11:50 PM
Omega
Aug 10, 2015 12:46 PM
