What are two holes for behind throttle bored in plenium?
Old May 5, 2008 | 03:57 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
What are the two little holes for behind the throttle bores on tpi pleniums? I have two different pleniums, an 86 and an 89 and both have the holes filled with carbon, what are they for, I'm guessing egr due to the amount of carbon.. what is a good way to clean them out? Also what is the small triangular hole for behind the throttle body on my 86 plenium and why doesnt my 89 have it?
Old May 5, 2008 | 08:54 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: What are two holes for behind throttle bored in plenium?
the 2 holes behind the throttle blades are for egr. you can clean them with a can or 2 of carb cleaner although prob not a good idea to do while its on the car. as for the single hole im not to sure.
Old May 5, 2008 | 09:36 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
EGR only on the later cars and EGR with cold start injector on earlier TPI's. The triangular hole is for the Idle Air Control on the earlier TPI. On the 89 and later they changed the throttle body design and they did not need the triangular hole.
Old May 5, 2008 | 10:12 PM
89RsPower!'s Avatar
I'm planning on using the 86 plenium on my 89, can I use the 89 TB with it or do I need to use the 86 TB? Will this cause any problems?
Old May 7, 2008 | 10:02 AM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
I think they have to match or the IAC won't work. One swap works the other doesn't but I don't remember which.
Old May 7, 2008 | 11:58 AM
Car: 1989 GTA
Engine: 369 TPI
I believe the 86 plenum has the triangle. It can be used with any throttle body.
Old May 7, 2008 | 01:49 PM
89RsPower!'s Avatar
I hope you're right! I'm gonna find out..
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Kenwood
Sep 4, 2015 05:50 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
