Manifold question
Old May 5, 2008 | 09:23 PM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Transmission: 700r/manual
Manifold question
Will the intake manifold from an 86 lb9 fit onto a 91 l98?
Old May 6, 2008 | 10:10 AM
upandcoming's Avatar
Car: 88gta
Engine: 357
Transmission: 700r4/3000 stall convertor
Axle/Gears: 9 bolt 3.27
Re: Manifold question
Bolt right up?? NO If you wobbled out the two center holes??? YES
Old May 7, 2008 | 12:23 AM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Wobbled out? Do you mean drilled out, or plugged up?
Old May 7, 2008 | 12:33 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
the two center holes on each side need to be elongated a little because the bolt holes on the heads are a different angle....now y do u ask????
Old May 7, 2008 | 12:41 AM
LouStugots's Avatar
Car: 2006 VW Jetta GLi
Engine: 2.0t
im new to tpi in general, can i swap a tbi manifold for a tpi setup or do they use different engine setups?
Old May 7, 2008 | 12:44 AM
Car: 1991 Z28 1LE
Transmission: 4l60e
a small block chevy is a small block chevy.....tbi intake will bolt on, tpi intake will bolt on, and carb intakes will bolt on....only main difference is the 87 up head two intake center bolts on each side are at a different angle....their are a few othe exceptions i.e lt1, lt4 and vortech heads....
Old May 7, 2008 | 12:56 AM
LouStugots's Avatar
Engine: 2.0t
hate to be annoying but i have no idea what to look for here... is this a complete tpi or is it missing the manifold?http://img.photobucket.com/albums/v6...dTPIfront.jpgi dont kno if it came out as a link u might have to copy and paste it
sry heres the link http://img.photobucket.com/albums/v6...edTPIfront.jpg
Old May 7, 2008 | 01:09 AM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
It's hard to see but it doesn't look lik there is an intake manifold below the tubes.
Old May 7, 2008 | 01:22 AM
Car: 1991 Z28 1LE
Transmission: 4l60e
no it doesnt have the bottom part. man im not trying to be an *** save ur money and go carbed cause if you dont even know if thats the entire setup i doubt youll be able to complete the entire tpi swap....
Old May 7, 2008 | 12:29 PM
camshaftxe's Avatar
Car: 91 rs
Engine: tbi 350
Because for the past few months Ive been buying parts for a tpi swap, and the intake manifold I have is for an 86 lb9, and Im installing my tpi stuff on a 91 l98, if that manifold doesnt bolt on, thats ok, I decided to go with an edlebrock base anyway.
Old May 7, 2008 | 02:13 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
o i got ya, well it will bolt on like i said with some grinding but if u are wanting the edlebrock base id definately go with that.... good luck man
anesthes
42
Oct 24, 2015 07:30 PM
transaero
Aug 31, 2015 01:14 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
