Motor install...Help
Old Oct 24, 2001 | 02:13 PM
craiger's Avatar
My friend and I plan to install a new engine in my 91 Z28. Is there any tips or tricks on the install? I've never changed a motor in a third gen and wondering if there are any secrets or good tips of advise?
And what about the break in period. Since I have a roller cam, do i need to break the cam in? Any help would be greatly appriciated.
Old Oct 24, 2001 | 02:17 PM
u r sofa king we tah did's Avatar
its pretty straight forward. id recommend pulling the transmission with the motor. take off all the vacuum & coolant hoses, disconnect all electrical connectors & air conditioning stuff. (be sure and label stuff since this is your first time doing this) then just remove the driveshaft, unbolt the transmission and motor mounts and pull the motor out. its really not that hard of a process, youll find this out once you get into it.
hydrolic144
Sep 8, 2015 06:55 PM
masonta
Sep 1, 2015 06:40 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
slade5612
Aug 11, 2015 07:19 PM
