man:( FP revisited HELP!!
Old Oct 24, 2001 | 04:35 PM
chevyboy07 91's Avatar
I'm trying to get this L98 in my 92 Z tuned for the citrus nationals coming up on Thanksgiving weekend. I am installing a FP guage (in car) b/c of the juice but just thought about something... Apparently you have to disconnect some sort of vacum line or something to get a proper FP reading correct? Otherwise you will get a low reading? Well, then the FP numbers I'll be seeing while running the car is gonna be false!! What do I do??? Am I missing something here? What do you guys w? in car guages do w/ this issue?
thanks
Alex A. (aka chevyboy)
1992 Z-28 L98/1LE. Heritage Edition. SLP runners, gutted cats, SLP 3" cat-back & muffler. 3" flo-tech cut-out, SLP TB foil, K&N filter @ TB, 3.23 posi rear.
Old Oct 25, 2001 | 12:33 AM
ttt....c'mon guys...any ideas????
Old Oct 25, 2001 | 01:44 AM
airdeano's Avatar
the vacuum line your referring to is the pressure
regulator line. senses the loss of manifold
vacuum (load) and richens the fuel circuit
by raising fuel pressure.
generally if you remove the vacuum line the pressure
raises 5-7lb.
this shouldnt interfere with your gauge.
your measuring line pressure. lack of pressure
means LEAN. so you need an adaquate
supply to the fuel feeder lines.
airdeano
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
88 350 tpi formula
Oct 24, 2013 08:50 PM
bobworkman
49
Feb 13, 2013 04:03 PM
ILMODC
Southern California Area
Nov 10, 2008 12:06 PM
9D1BURD
26
Aug 23, 2007 06:59 AM
