Is 230/236 cam too big for a superrammed 406?
Old Oct 21, 2001 | 08:02 PM
lexussc94's Avatar
I just ordered my roller 230/236 cam and I'm having second thoughts that maybe its to big. I need to pass emmisions. Heads are 190AFR, ported superram,and Accel DFI.
Anyone running this cam? Thanks
Old Oct 21, 2001 | 09:39 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Nope, I don't believe it will, but stranger things have happened.
A 218/224 probably will and a 224/230 just might if everything is "right on", but a 230/236 is a bit too big for the sniffer unless you ordered it on very wide lobe centers, like 114 or 116.
Even with the wide centers I don't think it will pass. The cam grinder should be able to tell you for sure.
Someone may know some tricks that may help though. There's gotta be a workaround.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9, TPIS Long Tube Headers and DynoMax Super Turbos (HATE 'em)
Old Oct 22, 2001 | 07:56 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
That's a pretty stout cam, but should work very well in the 406. Traxion has a 230/245 cam on a 113 LSA in his 350 and was able to pass emissions recently with his dual cats and a little PROM-burning trickery. If you get this cam on a 114 LSA, you'll have no problems passing emissions in your 406. I know guys with 224/230, 224/236, and 230/236 cams in 350 engines that have passed the treadmill test.
Greg Westphal
'87 IROC 355TPI/A4
Old Oct 22, 2001 | 08:01 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I used that cam in my 383 until this year when I went to a solid roller. I had the cam ground on a 112 lsa and 4 degs advance. Last year the car passed an IM 240 emissions test without a problem. The idle was very stable and the motor made good power with that cam.
Your motor has some similarities to mine, cam, AFR190 heads, DFI etc.
www.geocities.com/dzperf
D&Z Performance
"Putting Power to the Pavement"
Old Oct 22, 2001 | 09:46 AM
Guido's Avatar
Car: 2000 Trans Am
I had that cam in my 406 with a mini ram and it worked out good. I dont know if it will pass emissions but I think you can make it work to your advantage using the DFI.
Mine was on a 114 with +4 degrees in it as well.
-86 IROC
-=ICON Motorsports=-
Old Oct 23, 2001 | 11:18 AM
lexussc94's Avatar
Thanks for the posts guys. My cam has the 112lsa. Can anyone estimate the hp for me?
Old Oct 23, 2001 | 01:26 PM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
Mine made 385hp at the rear wheels with the initial tuning. I believe with the refined tuning that was done the rear wheel hp was closer to 390-395hp.
D&Z Performance
Old Oct 23, 2001 | 10:18 PM
lexussc94's Avatar
The guy I'm buying the cam from said it would make 450hp easily. So I guess I could use my 24# injectors? Thanks again
Old Oct 24, 2001 | 08:23 PM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I bought HiTech5's cam. It's still sitting in the basement next to about $3K worth of parts.
I'm doing a minirammed 385 with all forged internals, internally balanced. AFR195's (which I have not yet bought) with race porting. EA Pro puts the simulation at 510 HP at 6500 RPM, given a published set of modified AFR flow numbers and a 10.6:1 compression ratio. Torque hits at an estimated 4000 RPM and is predicted at an estimated 430 ft.lbs or so...
I'll be installing on a 110 degree intake centerline.
BTW, How did that solid roller cam work out?
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Old Oct 25, 2001 | 07:53 AM
HiTech5's Avatar
Engine: 383
Axle/Gears: 3.70
[QUOTE]Originally posted by ws6transam:
WS6Transam - The Solid Roller is pretty impressive. It has a sharper torque peak than the Hyd Roller and after 5800, the motor flies to 7000rpm. I'm a little concerned with the longevity of the shortblock spinning that much rpm though.
D&Z Performance
Jorlain
Oct 8, 2015 01:57 AM
middian
Sep 5, 2015 01:42 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
