ecm in limp home mode& code23 help please!!
Old Oct 26, 2001 | 05:38 PM
gta007's Avatar
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
Ok today i checked my 89 gta 5.7 on a scantool and the outcome was this. code 23, is MAT/ -40DEGF.the tool also said that the ecm is in LHM. would this cause the ecm to be in limp home mode or do i have a bad ecm?any help would be great! thanks in advance
89 gta 5.7 to many mods to list 89 formula 5.0 tbi (commuter)
Old Oct 26, 2001 | 10:46 PM
Vader's Avatar
GTA,
That means the MAT/IAT has either failed or is disconnected. It is located on the underside of the intake plenum. The sensor is about ten bucks. Before you get all wrench-happy to replace the MAT sensor, read this article:
MAT/IAT Sensor.pdf
You'll need Adobe Acrobat Reader to open/view/print the file (see below).
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Old Oct 28, 2001 | 10:29 AM
gta007's Avatar
vader, i replaced the MAT sensor yesterday. and i'm still getting a code 23 . i have a 52 mm holley tb and a ported plenum the same size. do you think thats causing the code. and if so do i need to move the MAT sensor?thanks for repling
Elephantismo
Feb 13, 2019 12:51 AM
2012sergen11
Oct 13, 2015 07:38 PM
customblackbird
Oct 1, 2015 04:30 PM
AmorgetRS
Sep 28, 2015 09:33 PM
Ranbo108
Sep 9, 2015 12:20 PM
