Where is it?
Old Oct 28, 2001 | 01:26 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
Where is it?
Ok, i am in a rush so unfortunetly, i cannot reserach this more...but could someone please tell me where the Cold Start Valve is on my TPI unit? I think I need to replace it, so that my car stops stalling when i start it cold. I will be replacing that, the IAC and the TPS...i am having lots of problems with the car's idle, and it likes to stall on a cold start and run really rough. So if someone could please tell me where it is on the TPI unit, so i can change it, that would be great. Thankx.
1986 WS6-Equipped 5.0 TPI Trans Am
180 Degree Thermo
Manual Fan Switch
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old Oct 28, 2001 | 01:51 PM
rondubbs's Avatar
its on the bottom of the drivers side runner,, in the middle of the tubes
ps. you might want to change the thermo time switch, locatred next to the coolant temp senosr in the front of th eintake manifold, this is the sensor that controls the cs valve..
[This message has been edited by ron rizzotti (edited October 28, 2001).]
Old Oct 28, 2001 | 08:39 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Hey Ron..
Thanks for the information...I havent had a chance to look at it today, but i will during the next couple of days...where is the coolant temperature sensor? I just hope i can get this d**n car running right. I hope its nothing to do with the injectors...I really hope not.
180 Degree Thermo
Manual Fan Switch
OTHER RIDE:
12/14 Options
Stock(for now)
Old Oct 29, 2001 | 02:28 PM
rondubbs's Avatar
no problem,
the coolant temp sensor is in the front of the intake manifold.. if you take off the air tubing to the tb you can see it better.
Old Oct 29, 2001 | 02:39 PM
86ZZ4's Avatar
before you go buy any parts,take the IAC off and clean it,we used to see lots of GM cars with that symptom at the shop.A good hard shot of choke spray healed a lot of em
86 z28 zz4 ssm lift bars ,3.73 simesed runners and a traction deficient 13.707@101.02,on a 2.16 60 ft on 295/50/15 junk street rubber ,best MPH run 13.82@102.7,69 AMX,390 4 speed sticky tires and other stuff..12.94@102.3
Old Oct 29, 2001 | 03:50 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Ron...
Took a look today between the tubes, and could not find it.
86ZZ4...
Yea, these symptoms are really driving me nuts. Stalls a few times when cold...rough idle when cold....when its JUST warmed up past 100 degrees, you could floor the car, and it hesitates badly...doesnt go anywhere...stumbles...shakes...its like i can hear a knocking sound almost...if i let off the throttle, it slowly speeds up. Low RPM at a stop sign, traffic light. But I will have to try that out...cleaning the IAC first.
Thanks guys for helping me out...I really appreciate your help!
180 Degree Thermo
Manual Fan Switch
OTHER RIDE:
12/14 Options
Stock(for now)
Old Oct 29, 2001 | 04:15 PM
86ZZ4's Avatar
hmm, the dieing problem when you floor it sound like you are dropping fuel prressure or have mass air flow taking a dump.My buddys TPI el-camino was doing that kinda stuff last week,felt like it was dropping fuel pressure to nothing ,turned out to be a MAF,also, it was setting no codes
Old Oct 29, 2001 | 08:12 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
I suspect it might be a fuel pump...the problem seems to be intermittent...not really constant...just got out of work....seemed to run good. And yea, i dont get any codes right now for anything. I was also thinking fuel injectors. I just want this damn engine to run good until i can get a REAL motor in it.
180 Degree Thermo
Manual Fan Switch
OTHER RIDE:
12/14 Options
Stock(for now)
Old Oct 29, 2001 | 08:34 PM
Vader's Avatar
This might help a bit.
The design view:
The real world view:
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 29, 2001 | 08:51 PM
PhantomTPI's Avatar
Engine: 5.0 TPI
Vader...
Thanks man..that definetly helps...you never fail to come through.....thanks a million!!
180 Degree Thermo
Manual Fan Switch
OTHER RIDE:
12/14 Options
Stock(for now)
