Is the exhaust crossover necessary?
Old Oct 29, 2001 | 10:42 AM
tyler's Avatar
I just got a set of performer rpm heads and was wondering what effect not having an exh. crossover would have.
I have read this is where the EGR ties in
I dont undergo a smog check or anything just wondering if the TPI will still work.
Old Oct 30, 2001 | 03:48 AM
TA88GTA's Avatar
double post. sorry.
[This message has been edited by TA88GTA (edited October 31, 2001).]
Old Oct 30, 2001 | 03:51 AM
TA88GTA's Avatar
I just bought the same heads and was wondering the same thing. The only difference is that I have to go through emissions tests, anyone know if ill be able to pass.
Old Oct 30, 2001 | 10:39 AM
Guest
Guest
Posts: n/a
The TPI will still work, although depending on the setup it may or may not have a fit and set a code. You can pass emissions without it.
Old Oct 30, 2001 | 06:16 PM
tyler's Avatar
thats cool thanks for the help
Old Oct 30, 2001 | 08:54 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I run those heads. No EGR hooked up what so ever. I run the stock 1987 5.7L prom. No error codes.
Never had the emissions tested.
So it should run for you. The emissions will depend on the rest of your combination, but there are people who have passed.
Mark.
zapr
Jul 27, 2018 06:03 PM
sailtexas186548
Feb 17, 2017 03:07 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
david068513
Sep 18, 2015 10:36 AM
