MAP or MAF?????
Old May 12, 2008 | 02:06 AM
tireburningZ's Avatar
Car: 91 Z28
Engine: 5.7 tpi
Transmission: t-5
Axle/Gears: limited slip 3.42
MAP or MAF?????
Please bare with me im new to the fuel injection area but when i bought my car the guy i bought it from said the car had the speed density system in it. Now if im correct (dont know if i am) the speed density system wasnt available for the 89 motor which is in the car but the car is a 91. my question is how do i tell if the car is map or maf for sure so i can get a new harness and also how do i find out if it is the speed density system? thank you
Old May 12, 2008 | 02:22 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: MAP or MAF?????
MAF car have a MAF sensor somewhenre between the Throttlebody and AIR filter.
MAf sensor to the left MAP sensor to the right.
/N.
You could also look at what number you have on your ECM, my guess is you have a MAP system with a 1227730ECM
Old May 12, 2008 | 05:03 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: MAP or MAF?????
Pretty much all of the engine parts will be the same, such as the intake, runners, and plenum. If someone replaced the original engine with an 89, that doesn't mean they used the mass air system from it. Most likely they've just replaced the engine block, and maybe the cylinder heads and/or intake as well.
Old May 22, 2008 | 12:15 AM
Car: 91 Z28
Engine: 5.7 tpi
Transmission: t-5
Re: MAP or MAF?????
ok so how can i know for sure because i plan on buying a new engine harness from painless wiring and thats two different setups i just want to be sure when i order it so i know which one its either going to be part number PRF-60103 or PRF-60102 depending on which one then ill have to collect an ecm from a junkyard or something.
Old May 22, 2008 | 12:33 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Re: MAP or MAF?????
Does the car have a MAF sensor (the big one pictured above) on the intake tube? If so, then it's MAF.
Old May 22, 2008 | 11:21 AM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: MAP or MAF?????
If your not sure what to look for under the hood, look at your ecm, if it has 3 plugs on it then it is map, if 2 plugs, it's maf.
Old May 22, 2008 | 12:41 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: MAP or MAF?????
If your not sure what to look for, post a picture of the engine bay, and you'll be told what you have in a matter of seconds....
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
aaron7
Sep 30, 2015 09:15 AM
