Cold driving engine knock and pinging
Old Oct 31, 2001 | 12:31 AM
Night Hawk's Avatar
Every cold morning I start my car, let it run about 5 mins before driving, then after about five minutes of driving I reach a hill that I have to climb.
When I climb the hill my motor stocks to knock, when the motor is at full temp it doesn't knock on that same hill.
I run 87 octane, all I can afford right now, I'm pretty sure this is the problem of the knocking and pinging, but I just thought I'd ask if there was any other possibilities....
Old Nov 1, 2001 | 02:17 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Check your timing. It could be off. Check your knock sensor too. If it is working properly then you should not hear any detonation because the timing would be retarded.
Good luck.
Old Nov 1, 2001 | 09:41 PM
CC's Avatar
CC
Car: 1989 Trans AM GTA
Engine: 5.7 TPI - Stock
That sounds like your ignition coil needs to be replaced.
'89 GTA 5.7 TPI bone-stock
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
