where can i find 52mm butterflies for my t/b??
Old Oct 31, 2001 | 02:51 PM
Fastcamaro87's Avatar
I plan on boreing out my stock 48mm to 52mm and i need to know where i can find the butterflies, any info will be greatly appreciated, thanks
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Nov 1, 2001 | 12:05 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
my friends dad bored mine to 52mm, he just built new butterflies out of aluminium.
My friend told me there is quite a bit of work involved in doing this .
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Nov 1, 2001 | 01:26 AM
age's Avatar
age
Car: 1992 Z28 1LE
I remember meeting someone that bored his 48mm to 52mm, and used the butterfly plates from a carb... can't remember which one, though, cause at the time I knew nothing about cars
Old Nov 1, 2001 | 05:52 PM
Hey ZEPHER,
are u saying that making the butterflies is a lot of work? or boring out the t/b to 52mm is a lot of work? I know its not going to be easy, but once i get it centered on the milling machine, i can just run a 52mm bit thru it,i guess ill have to call holley or something to find the butterflies
87 IROC-z 305 TPI
Old Nov 1, 2001 | 06:16 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I was going to post this question . I want to find them also.
[This message has been edited by IROC315 (edited November 01, 2001).]
Old Nov 2, 2001 | 10:20 AM
btt
Old Nov 2, 2001 | 02:58 PM
Zepher's Avatar
Oh, I should have clarified my statement.
The entire process of boring out the throttle body is a lot of work, making the butterflies is the easy part.
Usually the small screws that hold the butterflies to the center rod break, so you need to drill em out and re-tap the holes.
You have to cut off the end of one side of the rod to pull it out, then weld it when you put it back in. There is a small hole that needs to be filled in a little, since boring it out makes the hole larger and then you'll get this loud hissing sound that sounds like you have a vacuum leak.
Not way too difficult, relatively easy if you are a machinist. I couldn't do it,
so I had my friends dad who has a machine shop do it for me.
WS6 Trans Am.
Old Nov 2, 2001 | 10:36 PM
Mark_ZZ3's Avatar
Car: 1989 Camaro-1LE
Engine: TPI(s)
Transmission: 5 speed (MM5, MK6)
Axle/Gears: 3.45, 3.73
I have two 52mm blades that I salvaged from some other Throttle bodies. Email me if you are interested.
Mark.
Old Nov 2, 2001 | 11:00 PM
airdeano's Avatar
if you can find a metal works facility, have
them lazer cut them from a 48mm template,
but increasing the size to 52mm. $12? my
lazer cutter is working on it now...
will let cha know.
airdeano
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
