Intake Gaskets?
Old May 15, 2008 | 10:03 PM
fire350tpi's Avatar
Car: 1988 Pontiac trans am/gta
Axle/Gears: 3.23's
Intake Gaskets?
Hi guys, Ive got a 350 tpi
When i start it in the morning itll be fine.(rough but stable ) until i put it in gear and itll almost die then come back to life and have a slight hesitation.
Ignition system is intact
Icm is good
dist gear is new
Dist is reshimmed and in spec
new cap and rotor
msd 8.5 wires
All Injectors are over 16 ohms hot.
The curious thing is that im loosing coolant. So im thinking its a vacuum leak coming from bad intake gaskets. Thoughts opinons?
Old May 16, 2008 | 12:04 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Intake Gaskets?
The first thing is to find out where the coolant is going. Is the oil foamy? Is it dripping on the ground? Any white smoke when warm?
Old May 16, 2008 | 02:29 PM
fire350tpi's Avatar
Axle/Gears: 3.23's
Re: Intake Gaskets?
NO outside leaks, oil is perfect.
No smoke at all
Old May 16, 2008 | 10:13 PM
jv9999's Avatar
Engine: 5.7L/350
Re: Intake Gaskets?
No smoke at all
It's gotta be going somewhere. You might want to have the cooling system pressure tested.
Old May 17, 2008 | 06:00 AM
fire350tpi's Avatar
Axle/Gears: 3.23's
Re: Intake Gaskets?
Cooling system holds 20 psi with no leaks, as of last week
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Blue419
Sep 10, 2015 01:03 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
