my car changed its own oil !!! time for an Oil pump
Old Nov 4, 2001 | 01:55 AM
Fastcamaro87's Avatar
well the filter blew up like a balloon and all the oil spewed out, the pressure releif valve is stuck shut, and basically to make a short story shorter, now i gotta change the oil pump, well heres what i wanna know...
1. What things do i have to disconnect and/or remove to change the pump?
2. Is there anything else related, that i should consider changing while im at it?
3. And also if anyone has any tips or tricks to make this job any easier it will be greatly appreciated
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth,Factory Oil Cooler, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
Old Nov 4, 2001 | 02:19 AM
Zac's92's Avatar
don't mess with it in the car just pull it all the way out, it will give you alot less headaches. change the rear main while your at it.
Zac
Old Nov 5, 2001 | 12:32 AM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
It IS possible to change the oil pump while the engine is still in the car... I have done it 2 times so far (2 diff cars ). If you need to know how, email me, and I can walk you through it! Its accually not all that hard when you have someone whos done it before explain what to do!!!
-Rob
92' White Trans Am Convertible, 305 TPI, 5 spd. 2:73's, Edelbrock TES, Accell 8.8's, Hypertech Stage II, TPIS Air Foil, Ported Plenum, K&N TB Cone Filter, AFPR, & A Little Bit Of Attitude!
-Best ET: 14.944 @ 93.11
88 Gunmetal GTA Hardtop... Project In The Works!
"GUYS, WE NEED TO FIND A MUSTANG TO RACE... THERES ONE! HOLY SH*T SHES HOT! SHES NOT GONNA GO... NAH... HOLY SH*T SHES GOIN!"
RazorN8
Jan 7, 2022 11:44 AM
maroe624
Apr 16, 2017 08:29 AM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
MY87LT
Aug 17, 2015 08:43 AM
djmarch
Aug 9, 2015 05:27 PM
