Does anyone make a header spark plug for aluminum heads?
Old Nov 3, 2001 | 04:38 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
I can't seem to find any header (shorty) plugs for aluminum heads. Does anyone have a part#? I am having "issues" with my Edelbrock RPM's and my SLP 1 3/4 headers
89GTA-The Driver
92Z28-The Lawn Ornament
"Sunday Money"
Old Nov 5, 2001 | 11:03 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I use the AC Delco FR3LS, although it isn't a true shorty plug. It's the plug recommended by AFR and Trick Flow for their aluminum heads. You can try cross-referencing this plug and see which manufacturer makes the shortest plug.
Greg Westphal
'87 IROC 355TPI/A4
Old Nov 5, 2001 | 04:54 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Yeah, it's kind of fun to get in there isn't it? What I had to do was find a spark plug socket was made with facets on the ratchet end so that an open end wrench can be used to turn it. Then I had to cut it down by at least half, and drill out the square hole for the ratchet so that the spark plug will fit through it. Once you cut it short enough you can slip it on around the headers and you just use a wrench to break it loose and turn it. HTH
Black 88 GTA L98
271 RWHP, 344 RWTQ
13.406 @ 103.72 MPH
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back, Custom PROM (by me), in desperate need of stall converter
E.T.F.A Treasurer
Old Nov 5, 2001 | 09:21 PM
age's Avatar
age
Car: 1992 Z28 1LE
I have found that the Bosch platinums, and the Canadian Tire (because I see that you are a fellow Canadian) Motomaster spark plugs are the same length as the Accel shorty plugs. But I don't know if any of them have the gasket for alum heads... hope this helps.
Old Nov 6, 2001 | 06:01 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
My Rapidfires actually toch the headers when they are installed. I found a plug recommended by Edelbrock and I am going to do a little "dimpling". I am also going to try a set of those ceramic boot protectors. Overall I need to come up with about an 1" clearance. Would it be possible to "double up" the header gaskets to move the header away from the head?
89GTA-The Driver
"Sunday Money"
Old Nov 6, 2001 | 07:31 AM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
accel makes a header plug i use them exclusively when i tuned up my car.they make two kins for tpi the iron heads and alumiums.
Old Nov 6, 2001 | 07:54 AM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
I hate the Accel shorty plugs with the white hot intensity of a thousand suns. They were good for clearance issues, but I replaced them about once every six weeks.
Old Nov 6, 2001 | 11:48 AM
Car: 88 GTA
I used the Champions that Edelbrock reccomends. They're a tight fit, but I have at least a 1/2" of clearance around all of my spark plug boots.
Old Nov 6, 2001 | 09:13 PM
age's Avatar
age
Car: 1992 Z28 1LE
I don't see why you couldn't double up on the header gaskets.. my friend's dad and uncle who are old time hot rodders have done it before
Old Nov 6, 2001 | 10:42 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Thanks for the help guys. I've got a plan..........
1. Champion plug #RC12YC
2. Jacobs ceramic wires
3. "Massage" the headers
4. Double up gaskets
I need about an inch of clearance. If this doesn't work it will give me an excuse to get Hooker SCLT's
89GTA-The Driver
"Sunday Money"
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
