stock pressure 305 tpi 43-44psi?
Old May 20, 2008 | 08:17 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
just need a quick yes or no here.
i added a afpr to my 305tpi engine on my 86 trans am
what is the stock psi i should be reading with the vacuum hose connected and engien running? ive heard and read 43-44psi
is this correct?
ive also been told stock is in the 30's? but not sure if tahst even close to correct.
Old May 20, 2008 | 08:54 PM
Bobby_80s's Avatar
Axle/Gears: no idea
Re: stock pressure 305 tpi 43-44psi?
Ive been reading old posts from the search engine. still see only psi answers with the vacuum line off or just vacuum line on or high 30's mid 40's
just seems i cant get a clear answer across the board.
i can try teh dealership for answers, cant find anythign in my chiltons manual at the moment
jsut wondering if soemone isn't tired of answering this question can once and for all put this question to rest
Old May 20, 2008 | 09:17 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
is this correct?
My TPI setup originally came from a 1986 305 Camaro. The stock GM regulator is still set at 46 psi with the engine running and the vacuum hose disconnected.
Old May 20, 2008 | 09:43 PM
Bobby_80s's Avatar
Axle/Gears: no idea
is that with engine running and vacuum line connected at idle?
Old May 20, 2008 | 09:48 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Engine running, vacuum line DISCONNECTED. With it CONNECTED, it runs at about 38 psi. THe number with it connected will vary depending on how much vacuum your engine is making. The higher the vacuum, the lower the fuel pressure will be and vice versa. Its really only important that it drops when the vacuum is applied to it.
Old May 20, 2008 | 10:02 PM
Bobby_80s's Avatar
Axle/Gears: no idea
if you have high fuel pressure like lets say youre afpr is adjusted as low as it could go and you cant get it lower than 45-48 when it should be able to go way lower
could an air/vacuum leak be the cause of keeping your fuel pressure high?
jaridjohn
Jul 8, 2024 03:49 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
drathaar907
Aug 6, 2015 04:20 PM
