Heres a REAL TPI Engine!
Old Nov 4, 2001 | 11:36 PM
SoCo80p's Avatar
one guy i was talking with forwarded me his webpage about his 650HP ON MOTOR 427 small block with some custom TPI style setep, i was shocked when i first read it, im sure you will be also! here the link,.......
http://www.geocities.com/monty_willi...tallation.html
Old Nov 4, 2001 | 11:42 PM
BadSS's Avatar
<font face="Verdana, Arial" size="2">Originally posted by TempesT68:
one guy i was talking with forwarded me his webpage about his 650HP ON MOTOR 427 small block with some custom TPI style setep, </font>
Uhhh,,, that's a custom made sheetmetal intake,, well over $2000 just for it and the rails I'm sure. It is a killer set up regardless of how much the intake cost!
Old Nov 4, 2001 | 11:56 PM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
$2500, and that's not a TPI intake, more of a mini-ram/LT1 style intake (short runner design) AKA un-tuned or anti-tuned whatever. 18* heads. The only way to get further from a TPI engine than that would be to put a carb on it. Sorry, I hope that was a joke. Go search for 4 vavle chevy heads by Arao engineering, that's something exotic and interesting to post about.
14.62@96mph headers, muffler, chip, ghetto stuff, duct tape
89 GTA 305 TPI 5 speed 3.42 gears
Old Nov 5, 2001 | 12:22 AM
rezinn's Avatar
Im inspired. I hope I remember to make my own plenum and runners this summer.
Old Nov 5, 2001 | 12:36 AM
SoCo80p's Avatar
like i said some kind of custom TPI kinda like injected thing
Old Nov 6, 2001 | 11:59 PM
89ProchargedROC's Avatar
thats kinda pathetic for a solid roller 427 with 18* heads to ONLY be putting out 650hp
i mean i know people with 377s and 23* heads making 660hp and a 427 making 710hp with 23* heads....
doesn't make sense to me
Old Nov 7, 2001 | 06:09 AM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
I just love how someone posts something new and maybe interesting to some and everyone just starts ripping in, oh, 650hp, thats pathetic, etc. Man if you don't have something positive to post, don't! How many here have a motor putting out 650hp? Maybe this guy races in a restricted class. Maybe he is happy with 650hp. How many have the skill to weld up a new intake system. Geez it's like a drop of blood in the water and the know-it-all sharks come running.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Nov 7, 2001 | 07:31 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by Rob P:
</font>
That's exactly what I was thinking. I would not object to having that engine under my right foot I think the owner is a corvetteforum member.
Old Nov 7, 2001 | 08:16 AM
Guido's Avatar
Car: 2000 Trans Am
I wouldnt even put that in a class with TPI.
Awesome though. Id own it.
If you look close enough, see the hogan's sticker on the side? Those things are hell expensive.
Old Nov 7, 2001 | 10:43 AM
formul8!!'s Avatar
Car: 2004 GTO
Big bux.....nice though!
Old Nov 7, 2001 | 11:05 AM
86ZZ4's Avatar
Thanks ROB,LOL , I was thinking the same thing when I sgot to your post.
86 z28 zz4 ssm lift bars ,3.73 simesed runners and a traction deficient 13.707@101.02,on a 2.16 60 ft on 295/50/15 junk street rubber ,best MPH run 13.82@102.7,69 AMX,390 4 speed sticky tires and other stuff..12.94@102.3
Old Nov 7, 2001 | 03:47 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
just because it doesn't look like the 3rd gen tpi's does not mean that it isn't.gm has made two types of tpi's(TUNED PORT INJECTION)the l98/lb9's and the ls1's.anyone notice that it is a dry sump motor?clearly race only.i've seen that intake setup before it is a dual 4 barrel setup wth njector bungs welded in as well as a larger plenum to help high end hp.imho don't knock it if you cant beat it.
Old Nov 7, 2001 | 04:35 PM
David 91RS/Z28's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 89ProchargedROC:
</font>
So what do you have built that can compete with Monty's setup?? I thought so! Sounds to me like we have a player hater amongst us!
David Tuschhoff
1991 RS/Z28 Camaro
FI 355ci NA SBC V8 M5.
12.47 @ 110.7mph 1.80 60'
Best mph of 111.6.
My f-body page!
Old Nov 7, 2001 | 05:21 PM
GlennS87's Avatar
Monty posts frequently on www.corvetteforum.com. If you check out the engine mods section you will find he's very active and will answer any questions regarding this motor.
Neptune, NJ
White '87 Vette - 383 Superram ported and matched to TPIS big mouth intake, Eagle cast crank, 6"eagle forged rods, srp/je forged pistons, LPE 219 cam, ported heads(2"x1.56" ferrea valves), Comp cams pro-magnum 1.6 rr's, double springs, titanium retainers,Hypertech power coil and cap, 4 bolt block, TPIS headers, auto(trans kit,shift kit),Pro Torque 2600 stall converter, k&N filter, 3.07 rear diff., GrandSport brakes & rotors, Silver ZR-1 wheels 17x9 and 17X11
Old Nov 7, 2001 | 07:26 PM
JETHROIROC's Avatar
It's not pathetic like 89Procharged said, it's a nice motor....but I think what he meant was for the kind of damn money put into that engine it should be pushing out more than that. I mean, come on guys, lifters that are $200+ bucks a piece? This is an all-out race engine ($2500 crank, etc.), and therefore we should expect to see more extreme output.
That kind of power can be reliably made with a 427 at a far lower price, IMO. But again, it IS a nice motor, don't get me wrong.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Old Nov 7, 2001 | 08:13 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Their is difference between an engine with 650hp that is living on the edge and an engine with 650hp that will withstand the abuse. That engine was built with the best of the best parts so that it will survive.
Old Nov 8, 2001 | 06:49 PM
JETHROIROC's Avatar
Hmmmmm....so it wouldn't survive with about $800-$1000 in the crank and $500-800 in the rods (could be a $2000 total cost savings), or without $200 each for lifters, or with $1000-$1500 heads, or with $1500 for a miniram as opposed to $2500 for a custom intake? What about the Jesel shaft mount rockers, the timing set, the oil pan and let's not forget a $670 oil pump? There are plenty of ways to cut cost and arrive at the same output with equivalent durability, so I'm not sure I see your point.
Again, it's a nice engine, and I would like it under my foot too, but it IS extreme for the output.
[This message has been edited by JETHROIROC (edited November 08, 2001).]
Old Nov 8, 2001 | 07:10 PM
crucial's Avatar
Maybe some people just dont give a crap about cost and want the most expensive stuff they can buy. If I had LOTS of money I would too. Even if it "only" made 650HP !
1991 Z28 5.7 TPI
ZZ4 heads, ZZ4 cam, Harland Sharp roller rockers, Accel base, SLP siamesed runners, 52MM SLP Throttle Body, Hooker Headers, Flowmaster catback, MSD6A ignition, Home made ramair system, aluminum driveshaft, WC 5-speed etc
Old Nov 9, 2001 | 06:33 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
"To each his own"....Ever heard that? Some of you guys are ridiculous and are just plain haters.
Old Nov 9, 2001 | 11:50 AM
Guido's Avatar
Car: 2000 Trans Am
Someone lock this. There is obviously no technical content here.
-86 IROC
-=ICON Motorsports=-
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
