I'm Stumped
Old May 23, 2008 | 05:37 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
I'm Stumped
hey guys, i'm running an HSR with a custom prom with disabled security. I have fuel at the rail, and spark, but no fuel is making into the cylinders. i was running about 3200rpm in third, shifted to 4th for 30 seconds at 1800 rpm, pushed in the clutch, as i came to a stop the engine dies very softly, i barely even noticed. tried to restart, got a couple fires, now nothing, i pulled spark plugs and cranked it, no fuel is making it past the injectors, and no wires have been burned through. like i said earlyer, the security has been bipassed, but now when i crank it the security light comes on, which it never used to do. i 'm stumped and hop[e you guys can shed some light. thanks, alex
Old May 23, 2008 | 11:28 PM
not one's Avatar
Car: 1984 camaro
Engine: weezing 305
Transmission: th350
Axle/Gears: 7.5 3.23 mini spooled
Re: I'm Stumped
have you checked to see if any fuses are bad or if you are getting any power to the connectors for the fuel injectors?
Old May 24, 2008 | 12:02 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: I'm Stumped
all fuses are good, how would i check the power to the injectors? i'm pretty sure the injectors arent firing and thats whats causing the problem, the security light came on which makes me think vats, but it was disabled in the custom prom chip. is it even possible for the vats to re-acivate itself?
Old May 24, 2008 | 08:45 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: I'm Stumped
bump. i just checked fuses again so thats not it
Old May 24, 2008 | 11:17 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: I'm Stumped
ok i just bypassed the vats module, so the car turns over and i can smell fuel so i know its not fuel related anymore. i checked distributer cap and the coil they are in working order. the security light is still on, and when i conect the vats module back up it wont turn over. although vats was disabled in the prom chip? this is still happening. . early this week im gonna get a new chip burned and see if the old one was corrupted
Old May 26, 2008 | 12:49 AM
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: I'm Stumped
ok no spark is coming out of the coil, so my problem is either before the coil or the coil itself, but a coil wouldnt just go bad instantly would it?
Old May 26, 2008 | 12:58 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Re: I'm Stumped
If I'm not mistaken a failed VATS module can still cause a no strart condition.
Also chips/memcals/ecms can go bas as well. See if u can swap out with someone near you if u don;t find anything
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
djmarch
May 8, 2016 11:32 AM
Quzyle
Oct 15, 2015 03:35 PM
tuningnewb
Sep 23, 2015 07:06 PM
camarohelp
Sep 22, 2015 03:19 PM
