I'm stupid but i care!
Old Nov 10, 2001 | 04:21 PM
89tpi's Avatar
What is a miniram i am new to F-bodies and never heard of a miniram? Sorry that i am so stupid but my IQ may go up knowing this!
Old Nov 10, 2001 | 04:39 PM
smokin87iroc's Avatar
Car: 87 IROC
Engine: 305 TPI going to LT1
Transmission: 5spd
now ive never seen one but i think it looks like an LT1 intake but flows better.
Andrew
[This message has been edited by smokin87iroc (edited November 10, 2001).]
Old Nov 10, 2001 | 05:26 PM
BitchinCamaro's Avatar
It is an aftermarket replacement for the TPI. You can see it at www.tpis.com. It does look like a LT1 and flows similarly, but has a place for the thermostat and distributor. I am guess you are not yet prepared for a discussion of short vs long runner length and peak torque yadda yadda yadda. When you are do a search on the Miniram (in the forum) and you will find more info than you can handle.
Old Nov 11, 2001 | 12:48 AM
Car: 87 IROC
Transmission: 5spd
<font face="Verdana, Arial" size="2">I am guess you are not yet prepared for a discussion of short vs long runner length and peak torque yadda yadda yadda. When you are do a search on the Miniram (in the forum) and you will find more info than you can handle. </font>
in short..
long runner length (stock TPI) allows (forces) the peak torque at a lower rpm and so a shorter length (LT1 Miniram) allows (forces) the peak torque at a higher rpm.
it has to do with when the valve closes it makes a compression wave that travels up to the plenum (place before the runners) and then the wave travels back down. the longer the tube the longer the wave has to travel, and since the wave travels at approximately the same speed no matter what intake you use, the long runners take more time for the wave to travel thus needing more time between valve openings (low rpm) to let the wave help "push" more air into the intake. short runner does not need much time so it needs a less time (more rpm) between valve openings.
if i miss typed or said something wrong please correct me anyone but i think i at least got the jist of it all
Andrew
Old Nov 11, 2001 | 01:22 AM
Kyle F's Avatar
<font face="Verdana, Arial" size="2">Originally posted by smokin87iroc:
in short..
Andrew
</font>
Allmost, but the "short LT1 runners" are made to not tune the Rane for anyt rpm, but tune for ocverall performance. The ls1 is tuned for upper rpm use, but the miniram is made for over all flat torque. If you use a cam that picks up at 3000rpm and runs to 6000 Rpm then the Miniram is the choice.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
InfernalVortex
Apr 20, 2021 11:31 AM
Lbibb
May 5, 2016 12:00 AM
djmarch
Oct 2, 2015 10:41 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
