My formula shuts off around corners...
Old Nov 8, 2001 | 04:53 AM
mynyka's Avatar
Well It doesnt actually shut off but it does seem to die and then restart during HARD RIGHT turns. This usually occurs when I have 1/3 of a tank of gas or less which leads me to believe Im experiencing a fuel pressure issue of some sort. Has anyone else had this problem? By the way Its an 88 formula 350.
Thanks.
Drew
Old Nov 8, 2001 | 07:22 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
That's normal for earlier (pre-90?) third-gens. There is insufficient (or no?) baffling in the fuel tank, so the fuel pump inlet is uncovered. Do much more of this and you'll be replacing your fuel pump. Ask me how I know. I hurt my fuel pump mine in an auto-x by running less than 1/4-tank of gas, although it did last for several more months before I couldn't stand the aweful way the engine was running and had it replaced with a Walbro pump.
Greg Westphal
'87 IROC 355TPI/A4
Old Nov 8, 2001 | 08:57 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
There is an easy fix to this. Put gas in the tank or don't take turns so hard when near empty. Seriously though, same problem here I'm sure the extra 20-30lbs of gas right over the rear axle isn't gonna hurt you in anyway.
14.62@96mph headers, muffler, chip, ghetto stuff, duct tape
89 GTA 305 TPI 5 speed 3.42 gears
Old Nov 8, 2001 | 12:07 PM
Greg90iroc's Avatar
yea my RS used to do that but for some reason my iroc does not. It has to do with the lack of a sump or a swing arm in the gass tank of thirdens. Is your car TBI? I don't think it is a big problem for the tpi cars because of the much higher fuel pressure. when the car does that put gass in it. That is how i used to tell if i needed gass in the RS if it stuttered going arround a corner hard i knew i better get to a gass station. When i first got my iroc i thought i was getting low on fule so i took a corner hard and no studder i ran out of gass 2 miles later that was not cool.
90 IROC l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body, slp runners and some 1.6 RR's and a few other little things.
243 RWHP and 342 RWTQ with hot engine and 90 octain fuel
Old Nov 9, 2001 | 12:50 AM
mynyka's Avatar
Nope, my car is TPI. Its kinda lame that these cars were designed to handle fairly well but had no baffling in the gas tank to keep the pump submerged. It only happens in Right turns so I guess that the pump and pick-up are on the passenger side of the tank...
Drew
Old Nov 11, 2001 | 02:12 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
Yep, It affects all the early cars, even TPI's I'm building a AutoX/Road Race/ G-Machine, so I'm looking in to 1LE tanks or a custom fuel cell.
Linson
Oct 24, 2025 02:00 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
ironbmt
Sep 27, 2015 06:00 AM
