fuel flow problem
Old Nov 10, 2001 | 09:24 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
fuel flow problem
ok i hear the pump but i show no pressure
can the rubber fuel line from the tank collapse internally and cause a blockage similer to the brakes
any suggestions appreciated thanks
87 gta 5.7ltr
edelbrock headers
gutted cat
flowmaster 3in drivers exit
8.8mm wires/accel
accel 300+digital ignition system
msd pro billet distributer
hypertech stage 2 racing chip
slp cold air intake
maf has no screens
52mm bbk throttle body
extruded plenum, runners, intake all matched
high flow fuel pump
afpr @ 50 psi
ALL MODS DONE BY ME FOR ME
waiting on hotchkis rear susp package
and sfc before i run hard at track
Old Nov 10, 2001 | 10:55 AM
Vader's Avatar
Mean,
While anything is possible, it isn't very likely. It would be more likely that the pickup screen in the tank is clogged, the pump has become dislodged, the fuel filter is plugged, of the pump is failing.
Can you remove the fuel filter and test for flow to the filter? That would be a good starting point.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Nov 10, 2001 | 12:55 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
I had that problem before. You can hear the fuel pump run, but it had no pressure. Mine turned out to be the fuel pump itself bad. Had something to do on the inside of the pump. All I did was put in a new fuel pump and that fixed the problem. One thing I would recommend, is to go to the dealer and get an acdelco pump. You might spend a little bit more for it, but it will be better in the long run. My bad fuel pump was an aftermarket pump. "JUNK" Hope this helps.
1989 iroc-z 350 TPI, auto trans, leather int. t-tops, edelbrock headers and cat back system, SLP cam, crane double roller chain, 4 wheel disc, and aftermarket hood. Iroc-z's forever, Ford Mustangs NEVER
Old Nov 11, 2001 | 08:28 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
thanks for the help guys
i appreciate it
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
