Searched, now I need some help.
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
I have an L98 in my Formula
Car when cold will idle rough and stumble when applying gas, when its warmed up - runs great (except for a surge) will Idle from 800-1100 ish back and forth.
Could this be a bad CTS?
I know these things can do some crazy stuff, I just want to know. The motor sat for a long time before I put it in, I don't know if the sensor is gumed up and not reading right?
Sound probable?
Sound probable?
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Searched, now I need some help.
To me,it sounds like either a vacuum leak or problem with the IAC.
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Failed to mention, Brand new IAC and its been set properlly, new TPS, also adjusted, TB has been cleaned and decarboned aswell as plenum when I did motor swap.
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Vehicle has custom tune done, #24 injectors, AFPR - 47PSI at idle.
Runs awesome, pulls hard as hell right to 5000RPM, but just surges at idle when warm, and is stumbley and hesitates when cold as if its flooding
a friend of mine had a similar problem,we ended finding a crack in the IAC housing (thus causing a vacuum leak).Hope this helps.
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
That would make sence Tim, I appricate the advice.
Where abouts was your crack. I will look at it on my lunch brake, and possible use some JB weld.
Was it on the circle portion where it threads in?
it was on the bottom,we replaced the plate that bolts to the TB.
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Ill check that ill spray some wd40 under that plate and see if the idle changes.
Car: 1985 Pontiac TransAM
Engine: 400SBC 24x conversion
Transmission: T700r Stage2 Shiftkitted
Axle/Gears: 2.77 9 Bolt
heheh, his crack was on the bottom....
I believe I'm having a similar problem so when i get off my crack i'll have a look once all tpi stuff is off and hopefully save myself some time and money on other parts.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
bigjay89gta
Oct 15, 2015 08:04 AM
with TIMMYS89GTA sounds like the IAC needs cleaned.
