Motor dies when shifting from neutral to drive, park to reverse, etc.
Old Nov 10, 2001 | 04:42 PM
Adam62083's Avatar
Any idea on why? The idle either drops real low and comes back up or it drops so low the motor dies. It doesn't do it every time, its very random. If I do not hold the brake down all the way it seems to help. Is this low vacuum or something?
1992 Formula 350
-SLP 1 3/4 Headers
-Ported Plenum, Polished w/ polished runners
-Airfoil and other small bolt on mods
Old Nov 10, 2001 | 08:37 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Could be an issue with the IAC sticking closed (extended), or possibly too much gunk in the TB and it's passages.
Old Nov 11, 2001 | 07:27 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
have you checked for vaccum leaks?thhe idlee is set lower when in gear which means less vaccum and could cause it to die when putting it into gear.but i would say if it's a vaccum leak like that you'd notice it.it would ave to be a large port(like the brake booster line to the plenum)or like the other guy said the iac could be malfunctioning.....................
Old Nov 11, 2001 | 08:52 PM
nblanchard's Avatar
I would take your IAC out and clean it up, as well as the IAC passage.
Check for vacuum leaks by spraying TB cleaner by all the vacuum lines and intake gaskets.. listen for an RPM change.
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Best ET 14.559 @ 95.25MPH
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Nov 12, 2001 | 08:16 PM
MONTYR1's Avatar
Did you ever find out what the problem was? I am having similar problems and I am still working on it.
Old Nov 12, 2001 | 09:01 PM
5.7lformula's Avatar
I as well have the same problem. I however have no idea what a IAC is??
Jesse
Old Nov 13, 2001 | 12:17 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
IAC is the Idle Air Control valve. Your problem does sound like either a vacuum leak, a clogged IAC passage, or the minimum idle needs to be reset. There's a couple tech articles on how to reset the minimum idle.
Greg Westphal
'87 IROC 355TPI/A4
Old Nov 13, 2001 | 05:22 PM
MONTYR1's Avatar
I should be able to replace my iac this weekend so if it helps I will let you know. The iac has alot to do with the idle so I'm going there first, and then I'm checking my distributer and wires and timing, and finally My injectors, Then if no avail I will have to keep searching. I will let you know what it was maybe it'll help you too, I know the feeling of having this awsome car and can't enjoy to its fullest.
jklein337
Sep 19, 2018 06:23 PM
italiano67
Dec 11, 2016 09:21 AM
Andrew6.688
Dec 13, 2015 10:59 AM
TheExaminer
Aug 26, 2015 04:59 PM
hokis
Aug 9, 2015 03:57 PM
