CONFUSED?????
Old May 27, 2008 | 07:07 AM
blackwrestler34's Avatar
Car: 88 Pontiac Trans AM
CONFUSED?????
I'm not really sure if this is where this post goes but i need help and direction. I have an 88 TA with a tpi on an 69-79 350 block. Everything runs fine, starts up precisely, sounds great. But after about 30 minutes of driving when i press on the gas the rpms will decrease and the car will sort of "bog" out. when i let out the gas its fine. when i press it down again its fine for like a half a second then it does it again. If i really mash it try to see if it will clear up it will want to backfire. i can here it trying to come out the exhaust. The other day it did it and i tried to add some fuel system cleaner to see if it would clear up...no luck it did it again. I have a new Fuel Pressure Regulator, Hypertech AFPR, 22lb Accel injectors, ACCEL fuel pressure gauge. I NEED SOME TYPE OF DIRECTION. anyone have any pointers?
Old May 28, 2008 | 06:04 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: CONFUSED?????
hows your fuel pressure under load?
Galaxie500XL
Feb 1, 2020 04:53 AM
Jorlain
Oct 8, 2015 01:57 AM
sahlomonic
Sep 20, 2015 07:15 PM
bubbaz28
Sep 18, 2015 02:09 PM
Denricci22
Sep 18, 2015 09:02 AM
