TPI GIVING ME HARD PROBLEMS
Old Nov 5, 2001 | 12:42 PM
NEOMASTERZ28's Avatar
Car: 85 z28
When ever i drive the car around for a about an hour i will come to a light and when i come to take off i push the petal and it will just choke, hesitate and wont go no where. plus it jerks back and fourth like a rookie driving a 5speed when i push the petal hellllpppp !
i have new--- coil,cap,rotor,igniton module,fuel filter and still this problem
please help
and if any 1 in orlando/kissimmee area please e-mial me if you can help
ps. does having the fan on all the time an advantage ?
mods
K&n,jet air foil,air box modified and tb bypass
Old Nov 5, 2001 | 02:55 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Sounds like a bad/maladjusted TPS but it really could be practically anything. Start by checking the TPS, you can do a search and find more than enough info on how it's done. Depedning on year, it could be a MAF or MAP sensor problem as well.
Ed Maher - Moderator @ The TPI & Carb Boards
92 Z28 Convertible - Quasar blue / Tan top
305 TPI A4 2.73 - 14.7 @ 93.6
Stock except ported plenum and dual cats
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Nov 6, 2001 | 06:18 PM
TA88GTA's Avatar
Change the plugs. Did the trick for me.
Old Nov 6, 2001 | 08:17 PM
JAY87GTA's Avatar
I live over in Bartow, just south of lakeland. Did you check you timing? How often does it do this, ya know, hot, cold, ect. If you've done the tune-up stuff then it could very well be the TPS, or maybe the TB is full of carbon. Let us know what's up.
'87GTA w/ SLP Cold Air, MSD Coil, Airfoil, Gutted MAF, AFPR, TES Headers, HI-FLOW CAT, Flowmaster Catback, Energy Suspension Master Bushing Kit
Old Nov 7, 2001 | 12:14 AM
airdeano's Avatar
did you have this difficulty before or after
the parts addition?
several items to look into.
fuel:
filter, pressure, delivery.
computer:
TPS, CTS, knock sensor, EST.
exhaust:
restriction, collasped pipe, clogged cats.
tune up:
plug gap, coil output, wire resistance.
hope this helps
airdeano
Old Nov 7, 2001 | 03:56 AM
86TransAmTPI's Avatar
I had the same problem and it was because the MAF sensor was shot,the filament wire inside was broken.
86 Trans Am 305 TPI,Bored 30 over,Blower Cam,Fordged Racing Pistons,High Volume Oil Pump,3" Flowmaster Exhaust,Hypetech Coil,Acell 300+ Race Wires,Bosch Platinum +4 Plugs.Best Et was 12.5 with a Paxton.
Old Nov 7, 2001 | 06:09 AM
Mikel's Avatar
Check the TPS first. I don't know what the settings are supposed to be on a TPI, I'll *** ume they are the same as my GN, .46v at idle and 4.6 at WOT. (Someone please correct me if I am wrong.
If it's a speed density car, check the vacuum signal to the MAP sensor. The line should be soft and pliable, if it's hard, cracked, etc replace the vacuum line.
If you have a Mass Air car, let the car idle in park. Get out of the car and lightly tap the MAF meter with a small screwdriver or anything similar, if the car stumbles when you tap the meter, odds are it's shot.
This is assuming you have checked the obvious, fuel pressure, ignition, grounds, etc.
Old Nov 8, 2001 | 01:14 PM
Car: 85 z28
Well he is the up date on my ride ---
i just bought the ac rapid fires plugs new wires and the tps sensor and some superconcentrated fuel injector cleaner
and it ran good for about 30 mins then when i went to get get gas down the strret it statred again to jerk back and forth harder because it has more power now i guees cause of the tune up.
i was thinking can it be because of my systmen in my car i have 2 12" speaker right where the tank in the little well that hit pretty hard and i was wantering if that bass can mess with the fuel pump at all.
and so now what can it be now i think the maf sensor or if anything the fuel pump or just get the 350 ?????????? thnanks
Old Nov 8, 2001 | 01:27 PM
85transamtpi's Avatar
did you change the fuel filter?
It takes like 5 min
Old Nov 8, 2001 | 05:44 PM
rezinn's Avatar
.54v at idle 4.0 at WOT.. Any plug wires falling off or burning on the header?
Old Nov 8, 2001 | 07:32 PM
slowpoke's Avatar
Car: 1987 Z28
Axle/Gears: 273 Limited Slip
Are you running a cat or cats. Possible they may be heating up a stopping the ehaust up. This could cause these symtoms as well.
Old Nov 14, 2001 | 01:47 AM
If i was you,id look in the MAF and see if it looks like the filament wire is broken inside it,and make sure none of the wires going into the MAF sensor harnes connector came out.When i had the same problem as you i didnt understand,and it was as if i was giving the car gas and then letting up and giving it gas again and then letting up again when id try to drive with the bad MAF.Just take a peak inside and see if the wire looks broken.By the way,does your check engine light come on at all,and/or have you pulled any trouble codes?
jhawkeye
May 25, 2022 06:33 PM
maroe624
Apr 16, 2017 08:29 AM
db057
Aug 22, 2015 08:17 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
