Oil gauge fluctuates when engine is revved..help
Old Nov 18, 2001 | 02:05 AM
Voodoofighter's Avatar
When I give my L98 '91 Formula some gas, the oil pressure gauge jumps all the way to its farthest point, in other words, it redlines/maxes out.What could be causing this? The oil level in the engine is right where it is supposed to be, I don' burn any oil, etc...so what should I be looking for here as a fix? Thanks.
Old Nov 18, 2001 | 02:42 AM
breathment's Avatar
a new sending unit
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 18, 2001 | 03:46 AM
rezinn's Avatar
What is it normally at when the car idles? What weight of oil are you using? It may be accurate, high oil pressure is better than low oil pressure. I think the max is 60psi. My car stays at that until it is warmed up.
Old Nov 18, 2001 | 10:42 AM
No, it only happens under acceleration, which is not normal. I don't question the integrity of the oil pressure, but that of the gauge itself. Thanks for the replies.
Old Nov 18, 2001 | 01:01 PM
breathment's Avatar
i just reread ur post. 60+ PSI is fine, the higher the better.
- David
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
