Fuel Problems
Old Nov 16, 2001 | 03:41 PM
FatOne's Avatar
Fuel Problems
Have 85 Z28, recent rebuild.305 to 350 with 305 TPI sys. Already replaced fuel pump. Problems is it seems that the ECM is not sending signal to fuel pump and injectors. Do a direct lead on pump. Works and floods out injectors. The injectors seem that they arn't purging to the block? The check eng. light will not come on eighter. Tried a different ECM, but still having same problems. Can someone HELP...
Old Nov 16, 2001 | 09:31 PM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
well, i dont know much about this stuff but you can see if you fuel lines are in good condition and check your fuel sending unit.
Old Nov 17, 2001 | 10:14 AM
FatOne's Avatar
I have done this set plus checked wiring and all grounds in sys. I just have no idea.
Old Nov 17, 2001 | 11:21 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
1st check your fuel pump relay. It's located on the drivers side firewall ... I don't know which one it is but do a search on the message board and you should be able to find pics.. or you can ask Vader, he has pics.
2nd check your fuel pump FUSE.... it's NOT in the fuse box in the passenger compartment of the car. Rather it's under the hood somewhere. On my '86 it's on the drivers side up front near the battery. Again, Vader probably has pics of this fuse and where it's located.. he has an '86 also though.... not sure how many times GM relocated this fuse throughout the years.
Both of these items will cause the problems you're talking about.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
9 bolt Borg Warner Rear (2.77's....oh joy) :P
6" rods, approx. 9.7:1 Compression, Stock TPI (soon to be ported), 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, 1.52 RR (for now), Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech 53,000 volt coil.
Track times to come.
Old Nov 17, 2001 | 12:12 PM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
Check your ecm fuse and the power feed at the battery it is a fusible link that sometimes burns out check for power.
Old Nov 17, 2001 | 07:13 PM
FatOne's Avatar
Mr. Kidd are you talking about the circuit braker to reset the ECM? Ck'd fuel relay all wire look good and getting volts. Ck'd all the fusses there all good too. I'm really don't know what to check out anymore. When I crank up the motor and mist gas down the throttle it will run. It's like I'm just not getting the fuel to the injectors?
[This message has been edited by FatOne (edited November 17, 2001).]
Old Nov 18, 2001 | 08:35 AM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
Sounds to me like you are not getting voltage to the ecm do you hear the fuel pump come on when you turn the key on. Do you have a noid light that you could put into one of your injector harness connectors to see if the ecm is turning the injectors on when cranking the engine.
Old Nov 18, 2001 | 09:40 AM
FatOne's Avatar
Well yes I've got power to the ECM, and yes I can hear the pump come on with the turn of the ignition. I have not ran a direct to the injectors. From the ECM to the injectors? Other than Psi how can I tell if the injectos are giving me the right amount of fuel?
Old Nov 18, 2001 | 02:42 PM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
You need to check for a signal from the computer to the injectors you can use a noid light or a harness injector tester(60$ autozone)the light will flash when cranking the engine if the computer is seeing and sending a signal.If no signal no injector pulse.
Old Nov 18, 2001 | 06:09 PM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
Also check the two injector fuses in the fuse box if both of them are blown or have no current your problem is electrical.
Old Nov 18, 2001 | 06:10 PM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
