N2O on TPI?
Old Nov 18, 2001 | 01:52 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
N2O on TPI?
I've heard people running a system that has an injector in the intake tube. Does anyone make a plate that fits behind the TB that can be adjusted from 50-125. I have also heard of a problem w/ it puddling in the plenum and backfiring. Is this ture. Any help is greatly appreciated.
Mods: ZZ4 engine w/stock TPI, adj, fuel pres. reg., MSD 8.5, HI6S ign. w/ PS-91 coil, K&N filter, TPI air foil, Hooker comp. shorties, American Thunder flows. 160* stat., TB bypass, 3"cowl, bat. relocate, AC delete, stock T-5 w/ 3.42 rear, ported plenum, 24# inj.
Old Nov 18, 2001 | 04:49 PM
SLP-GTA's Avatar
Car: 1991 Formula (sold)
freebird, read this, made sense to me http://www.sc3gfb.org/resources/nos.html
I'm not new to nitrous, so I bought the NX
20920, nice kit great price, 465.00 to my door
hope this helps, Jim
Old Nov 18, 2001 | 05:14 PM
AlexJH's Avatar
Engine: 5.7L V8
Yeah, I was thinking about this myself. I'm assuming you're looking for a fogger system that injects N20 and gas through the same nozzle.
I know that TPI isn't designed to have gas flowing through the plenum/runners, so I was wondering if anyone had opinions on this, is it good/bad?
Old Nov 20, 2001 | 03:11 AM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
Hey SLP-GTA... could you please tell me where you got the kit for 465.00??? I'm thinking of buying it. Is it hooked up yet?thanks
Old Nov 20, 2001 | 07:21 AM
Desert86Roc's Avatar
The plate kit is #5151. The dry fogger system requires electronics, the "wet" plate system does not.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] www.MetzlerRacing.com
Best ET @ 1250 ft[*] 15.352 @ 91.215 mph (uncorrected)
Old Nov 20, 2001 | 11:31 AM
nblanchard's Avatar
I have a line on a NOS system from a buddy of mine.. he wants 350bux for it. Does the wet system cause backfiring, like the original question states?
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Best ET 14.559 @ 95.25MPH
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Nov 20, 2001 | 02:32 PM
86 IROC's Avatar
Freebird, have you ever heard of Rick Linstedt? He is in NC. Hell of a nice guy, he has a direct port Nitrous system that has a fogger for each cylinder. Each runer is tapped and has a fogger nozzle. He would be the guy to talk to about direct port systems on TPI engines. I have personally run a single fogger nozzle in the intake bellows. It works, though - some people have concerns about leaning the back cylinders out. Good luck.
1986 IROC, fully loaded, Mini Ram'd 383, Art Carr 700R4, Accel DFI, 12 bolt rear, etc, etc......
Old Nov 20, 2001 | 07:09 PM
To answer your question about backfiring....No, it does not any more than any other system. The only reason that would ever happen that the timing is too advanced (which you are not supposed to do anyway), or you activated the NOS below the recommended RPM (I know, I did it). Follow the rules and you dont have a problem. Been running mine for 5 years now.
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
