Factory injectors
Old Jun 3, 2008 | 10:34 PM
spoon911's Avatar
Factory injectors
I'm looking to replace my injectors on my '89 chevy camaro 5.7 tpi engine and was just wondering if anyone knows what that lbs of the factory injectors are? thanks.
Old Jun 3, 2008 | 10:45 PM
johnfwz28's Avatar
Car: 1987 Z28 Camaro
Engine: 5.7L TPI
Re: Factory injectors
i believe they are 22#. i have a set that i took out of my 87 z28. will sell for 40.00 shipped. let me know if you're interested.
Old Jun 3, 2008 | 11:07 PM
OutriderDriver's Avatar
Car: '88 GTA
Engine: 383 Edelbrock TPI
Transmission: Mad Dog 700r4
Ive heard technically theyre 21.9 lbs. and also in a magazine article that they were 24# Im switching mine out in a month. I wasnt thinking about selling, buy from john.
Old Jun 3, 2008 | 11:14 PM
the blur's Avatar
I hear 20.7 lbs
fact is no one really knows.
I wish I kept mine, and sent them out...............
Old Jun 4, 2008 | 09:53 PM
spoon911's Avatar
I was actually looking at the accel injectors, summits got 2 listings for factory injectors 21 lbs and 24 lbs. would it hurt anything by going with the 24lbs? My car hasn't really had any upgrades besides k+n air filter, accel 8.8 wires and super coil and also a Jet performance chip.
Old Jun 8, 2008 | 02:36 PM
rosco88ta's Avatar
Car: 88 Trans Am
Engine: 355 c.i.
Transmission: 5 spd.
Axle/Gears: 3:42s
305s used 19lb inj.and 350s used 22 lb inj. Upgrading to a 24lb inj would not be your best bet unless you are going to change things in the prom.
Old Jun 11, 2008 | 09:35 PM
spoon911's Avatar
my chip takes place of the prom, would this be considered a prom upgrade, enough to go with the 24lbs injectors?
Old Jun 12, 2008 | 08:54 AM
Car: '88 GTA
Again, replacement chips being crap anyway. It would still be set for what the car was equipped with. if you had a 305, put 22# injectors in, then put a jet chip for a 350 equipped car. That just might work. But the jet chip should be expecting the 22#s still. upgrading means reprogramming. But if you want to try it anyway, you can always switch them back....
Old Jun 12, 2008 | 11:11 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Stock factory injectors for the 350TPI were 22#.
Old Jun 12, 2008 | 08:37 PM
Abubaca's Avatar
Yep, stock is 22. Good luck finding them, and I wouldn't buy used injectors. No offense to any potential sellers. Stockers aren't that good brand new, and used ones, even IF they're good when they come out, they're highly prone to drying out once removed.
Ford 24 pounders are the best bet. Do a search.
....YES, they will require a custom chip, but you'll STILL come out cheaper than factory replacements AND you'll have much better injectors. If you can't afford it all at once, the car will run fine on the stock tune, but you want to get the new chip before tooo long.
Basically, the computer will compensate for the 24's, and it'll run fine. Problem is since it's on the edge of it's tuning parameters due to a change, if some problem ever occurs requiring MORE computer compensation, it's not able to make ADDITIONAL changes to the fuel curve since it's ALREADY on the edge due to the bigger injectors. Short term is fine(most likely), but like I said, get the chip.
Old Jun 12, 2008 | 10:13 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
i'm using the bosch III 22 in my car,, so are tons of l98 cars,, the mods jon @Fuel injector connection does makes them the same height as the multec.. drop them in an go.. no chip tuning or nothing. You don't have to lower the rail anymore.
Old Jun 12, 2008 | 10:21 PM
Abubaca's Avatar
If you can find the Bosch 22s, then you're good. It's the Multecs you wanna avoid. ....as for the height/fuel rail issue, I think we've pretty much proven time and time again that there are no leak/fitment issues with the shorter injectors. Any leaking issues are due to something else.
Thornburg
Aug 27, 2015 08:33 PM
mrestrictrplate
Aug 27, 2015 09:37 AM
eddie jr
Aug 25, 2015 06:52 PM
tmellott89
Aug 16, 2015 02:58 PM
fonzie85
Aug 13, 2015 11:50 AM
