305 TPI Question
Old Jun 4, 2008 | 06:51 PM
EKCamaro's Avatar
305 TPI Question
My wife and I picked up an 88 IROC for ME to redo for HER!!!! It has a 305 TPI engine (298,000 miles on it) that we would like to keep. My wife isn't into racing it or anything, just cruising it, so I figure a basic stok rebuild but would like to get a little more power out of it. What could I do to this engine, gasket match and smooth the runners, headers, edelbrock intake upgrade? It already has a K&N and a dual exhaust is a definate.
Thanks guys,
eric
Old Jun 4, 2008 | 07:36 PM
billybird's Avatar
Car: 89 Formula
Engine: LB9 TPI
Axle/Gears: 3.73(coming soon)
Re: 305 TPI Question
just redo the car for YOU..instead of the boss...
i like intake.headers and gears(3.42/3.73)...will deff wake that 305 UP!!
Old Jun 4, 2008 | 09:09 PM
EKCamaro's Avatar
Thanks,
actually I have my car finished, 73 Dart, So this one is for her.
Old Jun 7, 2008 | 05:23 AM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
unless your doing the work on your own, maybe buy a newer 305?
Old Jun 7, 2008 | 11:23 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Rebuilding the engine with 300,00 miles, will increase power. That is a roller block so up grading the cam would be easy during a rebuild. Rebuilding/upgrading the heads will increase power. I this a manuel or stick car? I understand the stick cars have decent cams in them, same as the 350 auto cars, now is a good time to confirm that and or fix it. Lots of little tings add up to. Double roller timing chain, roller rockers or roller tip, squaring the block, making the heads flat, good pistons. with all the other normal stuff on intakes and such. There is a post here with a guy getting like 347 rwhp with a 305.
Old Jun 7, 2008 | 11:59 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
You can buy a remanufactured 350 long block for about the same it costs to rebuild the 305 (and you'd save TONS of time) ... and you can swap over 95% of the parts. I think that would be your best move.
I'll bet you One Bazillion Dollars it's not a TPI, though!
Old Jun 8, 2008 | 12:24 AM
The post I mentioned is still active. Go to the TPI posting board and about the 30th one down will say "356 WRHP TPI 310 build", I though it was 347...woops missed it by that much. I wish you had one bazillion dollars to lose. I test drove a 91, 305,T5, TA the other day and it had plenty of power even at 2,000 rpm's.
Old Jun 8, 2008 | 03:43 AM
Nater36's Avatar
thats the problem gulstrand... tpi HAS LOW END POWER and not upper end.. torque not hp
Old Jun 8, 2008 | 03:04 PM
Did you check out his post? 356 RWHP is alot to me. The TQ curve is flat to 6000 RPM, over 300 RWTQ for many thousand RPM. The TQ peaks at 362 RWTQ or there about, whick agrees with what you said only more RPM range. Annything with 300 RWHP or TQ is a awsome street car which ever it has. He has the best of both worlds. Check out his post, He lists the parts in the motor.
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
