What fuel pressure gauges are you guys using?
Well now that I have an Auto Xray 10110 (new version replacing the 240) want to get the next diagnostic tool..........fuel pressure gauge. What are you guys recommending, and do you leave it on the motor when you drive (tape it to the windshield as a buddy of mine used to do) to watch it?
'79K5 Blazer with 406TPI
Car: Red Rooster
Transmission: M5
There are different types of gauges. One that screws into the shreder valve and stays there all the time (little short one) and the other type is the one with the long hose that also screws into the valve.
I am running the one with the longer hose, more popular and cheaper too. I do not know the brand name.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Headers, Hooker Y-Pipe, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, K&N, AFPR, All free mods,
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
I have a gauge that I used to tape on the windshield but now I'm going to get autometer elec.gauge for 200$ and mount inside to see the F.P all the time....
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods,looking for a SR ...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I'm using the Accel fuel pressure guage that mounts to the fuel rail and stays in place. Can't see what's going on driving down the road but then again, I'm not exactly to that point yet in my performance issues. I got other bugs, so to speak, to work on first.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
9 bolt Borg Warner Rear (2.77's....oh joy) :P
6" rods, approx. 9.7:1 Compression, Stock TPI (soon to be ported), 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, 1.52 RR (for now), Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech 53,000 volt coil.
Track times to come.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
I am using the Autometer 2 1/16 dia o/100psi FP gauge with the 3ft ss hose. The gauge is in a Autometer mounting cup located under my
STB on the inside fender by the strut support.
Nice protected location under the hood and
out of the way and still visible. I purchased all the items from Summit.
<font face="Verdana, Arial" size="2">Originally posted by Z28DJP1987:
</font>
</font>
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Im running a similar autometer setup, with 4 feet braided hose. I have it bolted to my hood tho.
Cost about 65.00 from Summit. I'm using Sunpro mounting cup bolted to hood. (sunpro is snap-on).
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters, Summit 1.5 roller rockers, World Products Sportsman II
2.02/1.60 heads, Edelbrock TPI Intake, Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
-- Joe
-- Joe
-- Joe
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I have an Autometer 0 - 100 psi Pro Comp Ultra Lite 2 1/16" electric gauge. I used some A/C refrigerent hose with an adapter to go from the shroeder valve on the fuel rail to the electric sender that comes with the gauge (I am pretty sure that the adapter to go from the sender to the refrigerent hose came with the gauge as well.... having a hard time remembering, but I can dig out the literature for the gauge and check if you want). I then ran the wires off the sender up to an Autometer dual gauge pod inside the car. It works great and I verified it to be accurate with a mechanical fuel pressure gauge that I have. The Autometer gauge and the pod are available through Summit and I think I got the refrigerent hose (high pressure) from a local auto parts store....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
1987 GTA L98 MD8
My GTA
Car: Trans Am
Car: Trans Am
Ok, heres a picture.
My questions are:
1: Is the gauge inlet on the bottom back of gauge (as in picture)?
2: Is the cup outlet on the back of the cup (as in the picture) or on the bottom, by the mounting bracket?
3: Can the cup be mounted at a angle (as in the picture), but still have the gauge horizontal?
My questions are:
Transmission: A4
Im running a 2 5/8 auto meter phantom gauge imounted in the cowl of my hood. It is a mechanical gauge. I want spending $200 for the electrical one just to have it inside. I paid about $40 for mine and bought a 6ft length of braided line for a nitrous kit. I did have to get an adapter to mount the line on the shrader valve though since it was the stupid amercian thread size. I post a pic but my son smash my scanner today. hes only 18 monthes old though so Ill wait until hes 13 or so to punish him
1987 GTA L98 MD8
My GTA
1987 GTA L98 MD8
My GTA
Car: Trans Am
OK, but I can't see in your picture how the gauge is located. I'm assuming the cup is mounted sideways on the inner fender, but is the gauge horizontal, or is it sideways like the cup?
Oh, and also, is the inlet on the gauge male or female threads? I want to go fron a -4 AN fitting to the 1/4 or 1/8 NPT fitting, but the only adapters I see in Summit are male to male.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Nordskog digital fp gauge to autometer dual pod. I mounted the sender to the crossover on the fuel rail (leaves schraeder available)
accurate according to my mech fuel pressure tester
80 bones
80 bones
The Gage is mounted horizontal. Why do you want to change fittings?? As long as you get the SS braided hose with the -4AN
you should have no problem from the Schader valve & Autometer
FP Gage.
FP Gage.
Car: Damn
Engine: This
Transmission: New Stuff
I too have the Nordskog electric gauge inside and a mechanical gauge under the hood.
The Nordskog is very innacurate and reads in a quarter circle in not so usable increments. labled 0, 25, 50, 75, 100. with little hashes inbetween that are soooooo close together because the gauge's sweep is so small. I would not recommend this gauge, I use it mearly to make sure I have fuel pressure at all because its not much use otherwise. it reads somewhere around 30 psi (hard to tell) when pressure is actuall 42 psi.
Even if it were accurate, you can't easily check pressure at a glance.
Just my experience and my opinion.
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
