what is the culprit????
Old Jan 23, 2003 | 07:18 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
when i start my car it runs for like two seconds then dies. then it starts and runs like it is supposed to. it idles real rough ( 70% of the time) and sometimes bucks in 1st gear, and i can get on it and it clears up but the idle still messes up. all this started to happen after my cat went out and was replaced by a straight pipe. any suggestions are appreciated. thanks
Old Jan 26, 2003 | 06:23 PM
bubbz89's Avatar
Car: 1990 RS
anyone???
Old Jan 26, 2003 | 09:58 PM
breathment's Avatar
have u done a tune up? do u have any compression readings or vaccumm readings or fuel pressure readings to help us diagnose this problem? u said it idles rough 70% of the time. does it still idle rough once its warmed up?
Old Jan 27, 2003 | 03:58 PM
bubbz89's Avatar
Car: 1990 RS
full msd tune up with about 1200 miles on it. fp was 39 the last time i checked and i dont have any comp. readings but the motor only has 22k miles on it. one of my buddies mentioned an iac motor, but i dont know. it still messes up when warm to. i have a thermomaster chip and a 176/166 fan switch so it doesnt get real warm. does the chip compensate for the low running temps as in closed loop? thanks
Old Jan 29, 2003 | 09:45 PM
bubbz89's Avatar
Car: 1990 RS
anyone????????
Old Jan 30, 2003 | 05:45 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
That almost sounds like it could be a throttle position sensor or the Idle air control valve... does the check engine light come on?
Old Jan 30, 2003 | 07:59 AM
bubbz89's Avatar
Car: 1990 RS
i havent had any check engine lights. i tested my tps and it was fine. i am prolly just going to buy an iac and see if it helps any. thanks
Old Jan 31, 2003 | 06:06 AM
Yeah I know somebody who had similar problems with his firebird... it turned out that the IAC valve had gone bad.... My suggestion would be to try that out and see what happens with it... good luck.
Old Jan 31, 2003 | 08:20 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I too ran into a problem SIMILAR to this .......
I had ONE bad injector ..... no ses light ...... put it on a snapon diagnostic box of somesort ( when I could keep it running )
juts my two cents ........ I know this isn't related to you doing the exaust work ......... but it was wierd how this showed up for me ....right after I did the timeing chain. ( I thought the chain was on wrong )
Old Jan 31, 2003 | 05:30 PM
bubbz89's Avatar
Car: 1990 RS
thanks guys
Old Feb 1, 2003 | 09:12 PM
bubbz89's Avatar
Car: 1990 RS
i noticed today it bogs worse after driving it and then letting it sit for like 15 or minutes. also it bogs while driving a little too. could an iac cause drivability probs as well as idle probs? thanks for all the helpl guys!!
Old Feb 6, 2003 | 08:38 PM
bubbz89's Avatar
Car: 1990 RS
anyone???
RedLeader289
Sep 23, 2015 06:50 AM
crazynights
Aug 21, 2015 06:53 AM
hellfire
Sep 9, 2002 01:55 PM
Mkos1980
Aug 29, 2002 07:40 PM
