whats the best idea to mod your stock air box on a 85 t/a? i know you cant cut the sides since it breathes through the top of the air can can i do some cutting on the bottom for maybe a pony or 2??
any one have any pics
68 RS/SS Ragtop
close
- Join DateSep 2002
- LocationColumbia, SC/ Middle East
- iTrader Positive Feedback100
- iTrader Feedback Score(2)
- Car68 RS/SS cnvrt, 92 Z28, 02Blkbrd
- Engine295hp 350, 385hp 350, 420hp LS1
- Transmission4spd, 700r4, T56
- Axle/Gears3.11, 3.23, 3.42
- Liked:0 Times in 0 Posts
Hawks sells a ram air duct that runs from under the front bumper. It gives better/direct airflow to the filter. I've seen a pair installed on a 91 Z28, I'm not sure if it fits a FireBird, but you might want to check them out.
Also if it's a tpi set up, you may want to consider a smooth bellows between the airbox and the sensor, it cuts down turbulence.
