Smog pump
Old Jun 6, 2008 | 07:07 PM
skiroulertx447's Avatar
Car: 86 Z28
Axle/Gears: 3.42 posi
Smog pump
My 86 Z28 with a 305 TPI has the california emissions on it, I'm in MN now and plan on keeping the car forever, no rust, needs paint. Can I remove the belt for the smog pump and have the engine function the same as with it on, how much power will it gain from doing this, or do I have to remove all the emissions stuff to make it work? Will the computer say something is wrong? Also can I remove the catalylyic(spelling) converter with out it affecting anything?
Old Jun 6, 2008 | 08:13 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Smog pump
put on a high flow cat,and leave the pump on it (no power gain by removing it),later jimmy
Old Jun 6, 2008 | 11:04 PM
Car: 86 Z28
Re: Smog pump
I find that hard to beleive, there has to be some kind of power gain or mpg gain when removing the air system. So you can't remove the cat completely?
Old Jun 7, 2008 | 05:06 AM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
Re: Smog pump
your fine to remove the cat, no problems there... but the smog pump you would have to remove it from the ecm or it wont run properly
Old Jun 7, 2008 | 06:28 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Smog pump
Not true, I have no smog pump, and my ECM works fine. No error codes, and I even passed TX emissions like that. However, with that said, you won't really gain anything noticeable by removing it, the air pump doesn't really take much effort to turn. We're talking about maybe a 1HP increase, at the flywheel. If the system is working properly, I'd just assume leave it in place. If you really want to do it right though, it can make a little more room in the engine bay though. Get headers without air tubes, and a 2-way cat that doesn't need an air line. My only complaint with the air injection is that the tubes make it a pain to get to the passenger side spark plugs.
Old Jun 7, 2008 | 08:46 PM
Nater36's Avatar
Re: Smog pump
well according to a tech article on this site, you need to remove all of the air system or it could cause problems...
Old Jun 7, 2008 | 08:58 PM
Car: 86 Z28
Re: Smog pump
Well I'll probably leave it until I drop a 350 in it.
Old Jun 7, 2008 | 10:02 PM
Nater36's Avatar
Re: Smog pump
sounds good... i thought about removing mine as well but its only a small weight gain and as most ppl said small hp... I've heard up to5hp....
Old Jun 8, 2008 | 01:23 PM
dholm's Avatar
Car: '88 Camaro IROC-Z
Engine: 350TPI
Transmission: TH700R4
Re: Smog pump
I've heard the gain is closer to 0.5-1hp. I just removed the smog pump on my '88 and I can confirm that you do not have to do anything to the ECM. I did it to clear up the engine compartment and get rid of those pesky air tubes in the exhaust manifolds but it turned out the bearings in the smog pump were in less than good condition so it was a good idea no matter what.
Instead of rerouting the belt I decided to get a delete pulley so I could remove all the clutter. I left the AIR-tubes in for now but I'm gonna remove them as soon as I get a chance.
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
