Fuel Pressure Gauge
Old Nov 24, 2001 | 05:51 PM
WS6Formula350's Avatar
Fuel Pressure Gauge
I wanna put a fuel pressure gauge on my window pillar. I know that i can't bring fuel into the car. I have heard about water convertions but i don't know where to find them or how much. can someone help???
Old Nov 24, 2001 | 06:58 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
If you find out, let me know. I've thought about doing the same thing but they don't make the fuel pressure gauges with isolators for TPI. 45-50 psi is kinda hard to isolate I guess.
1986 Trans AM
355 TPI
4 Wheel Disc Brakes
9 bolt Borg Warner Rear (2.77's....oh joy) :P
6" rods, approx. 9.7:1 Compression, Stock TPI (soon to be ported), 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, 1.52 RR (for now), Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech 53,000 volt coil.
Track times to come.
Old Nov 25, 2001 | 02:34 AM
poncho9789's Avatar
It's quite expencive but,you can get the electric autometer guage to run inside the car. I think they cost like $180.
Old Nov 25, 2001 | 03:00 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Autometer makes the high pressure 0-100 psi isolator, don't have the PN on hand but Summit does carry them even though it's not listed in their catalog. You use antifreeze between the isolator and gauge but it can be a PITA to set up.
I'd get the electric version instead.
1989 IROC-Z, ZZ3 shortblock with some bolt-ons.
13.20 @ 108.69, 2.2 60'
Old Nov 25, 2001 | 10:41 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The electric setup is not much more, and you dont have to use autometer either.
Summit tried selling me an electric unit with a sender when I bought my mechanical. I wanted it mechanical and mounted outside,
so thats what I bought. But overall, the electrical setup was only about 30.00 more than the 80.00 I spent.
Rather than buying 40.00 line, you buy a
40.00 sender, and the gauge was prolly 20
or 30 bux more or something.
-- Joe
1989 Formula 350 4-bolt mains, Forged .030 TRW pistons, SLP 51010 Roller Cam, Comp-cams roller lifters,
Summit 1.5 roller rockers, World Products Sportsman II 2.02/1.60 heads, Edelbrock TPI Intake,
Cloyes Double Roller, timing chain, Mellings oil pump: 13.5 @ 100.23 MPH
Since close of track : Ported SLP runners, Ported Plenum, AFPR, Autometer 100lbs gauge, A/F ratio gauge.
http://www.joesperformance.com
Old Nov 25, 2001 | 11:05 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I have the Autometer Phantom Electric gauge in my a-piller. I forget what I paid for it because i also got a Tach and water temp and the dual piller pod.
I say get the gagues you want spend the few extra bucks for the electric one.
92 25th Anniv. Z28
383 Stroker/Lunati Pro Mod Lowerend
AFR 210cc Heads,Solid Roller Cam,
ArtCarr 700r4,Strange 12bolt
Old Nov 25, 2001 | 11:29 AM
Erik formula L98's Avatar
I was going through the same problem but I decided to go with the mechanical gauge and mounted it where the formula scoop is. Here are some pics:
http://www.geocities.com/formulal98/gauges03.jpg
http://www.geocities.com/formulal98/eng2-801.jpg
Erik '89 Formula 350 TPI
13.96 @ 97 on motor
12.63 @ 111 w/NOS
[This message has been edited by Erik formula L98 (edited November 26, 2001).]
Old Nov 25, 2001 | 01:35 PM
thanks guy. i was looking through summit last night and i saw the electric gauge, was gonnna ask what u thought but now i know and that's what i'm gonna do.
Old Nov 25, 2001 | 05:11 PM
I just looked a the gauges in summit (again) i saw the Autometer Phantom Electric gauge and i was wondering if it came w/everything i need to hook it up to the pillar or i had to buy a kit to install it. I didn't see one. Let me know here
Old Nov 25, 2001 | 07:29 PM
poncho9789's Avatar
The guage should come with everything you will need to install it except the piller pod or the hardware for however you decide to install the guage.
Infested
May 22, 2018 11:56 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
ChevyZ71
Aug 13, 2015 07:30 AM
Kaweh
Aug 9, 2015 02:54 PM
