car dies at top end of track EVERYTIME..
Old Nov 23, 2001 | 10:42 PM
BigMike92Z's Avatar
Car: 2006 Pontiac GTO
Transmission: rowing through 6 gears
ok so when i make a pass i get to the top end of the track and the car dies. usually happens around 90 mph at about 3500-4500 rpms (havent looked down to check yet). we were able to duplicate it by revving up to 4500 and then the engine just dies. when you go to start the car again it runs very rich for a second which tells me it is losing spark but not fuel. checked the coil and it is checking out fine. tried replacing the map sensor to no avail. any suggestions? also car is a 92 Z28 with a 350..
Old Nov 24, 2001 | 09:28 AM
kevinc's Avatar
Car: 1982 Z28
A scantool will make troubleshooting much easier, so you can see what's going on as well as posting a data capture for people to analyze and help diagnose.
Also, you might connect a fuel pressure gauge and duct-tape the head to your windshield so you can see it while driving. If your pump or regulator are dying, you'll see pressure drop big-time just before the engine dies.
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old Nov 24, 2001 | 10:18 AM
nblanchard's Avatar
Check your Throttle Position Sensor voltage at wide open throttle. My car had the exact same problem, and it ended up being a bad computer. The TPS was only seeing 1.4 Volts.
1988 Pontiac Trans Am GTA L98 5.7L, Black on Black with 114,000kms.
Best ET 14.559 @ 95.25MPH
Custom 3" Stainless Exhaust Y-Pipe back (High flow Cat and Flowmaster Mufler)
Old Nov 24, 2001 | 09:30 PM
Little GTA's Avatar
Is your motor heavily modified?
Sounds like you could have too much power, but a lot of back pressure in the form of restrictive exhaust manifolds/pipes.
Or maybe your just getting too much fuel and flooding out...any black smoke coming out of tailpipes?
Just a thought.
89 TransAmGTA L98/Auto Grey/Grey T-Tops
Best 1/8th: 9.02 @ 76
89 TransAmGTA LB9/5speed FlameRed/GreyLeather Hard Top
Old Nov 24, 2001 | 11:27 PM
Bad Blk Z's Avatar
thanks guys.. i replaced my stock chip with a friends stock chip and it seems to be working. i guess we'll find out after the next trip to the track.. but during road testing it seems to work...
https://www.thirdgen.org/rides/index...ew&riedid=6260
91 Z-28 Coupe
L-98, 700-r4
https://www.thirdgen.org/rides/index.tgo?action=view&riedid=6261
race Car:
S/P 91 Camaro Z/28
454 LS7 crate motor
Old Nov 25, 2001 | 09:23 PM
BigMike92Z's Avatar
ok that above post was from me just i was at badblkz's house. sorry bout that. thanks again though guys.
midge54
Dec 27, 2019 04:14 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
