What effect does removing a smog pump and all accessories from a 305 tpi have?
Old Nov 29, 2001 | 02:25 AM
digimagix's Avatar
I have an 88 Trans Am all stock, i want to remove the smog sh*t including all the air tubes, hoses, pump, and the little black box with two wire connectors leading to it, i am thrown off and dont know what effect this will have and if it is computer controlled or not. someone plese help. email me or post here, thanks alot.
Erik
digimagix aka jinxed
jinxed@digimagix.com
Old Nov 29, 2001 | 05:05 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You can remove all the A.I.R. stuff (smog) and be just fine. Cleans up the engine bay greatly. Leave EGR alone unless you burn a new prom though.
86 Camaro Sport
LT1 Induction
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Hooker Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Moderator at SE ThirdGen
Old Nov 29, 2001 | 01:27 PM
RyIROC13's Avatar
Car: 1987 IROCZ-28
Transmission: 700-r4
I've taken mine off and have not had a problem with it. Just take your time and do it right.
Old Nov 29, 2001 | 05:51 PM
1986CamaroIROC-Z's Avatar
what can be taken off? My engine is way too cluttered and am lookin for a way to get rid of unneccesary stuff. What items can be removed?
1986 Metallic Blue IROC-Z
80k miles, 305 TPI
Mods:
-Edelbrock Hi-Flow baseplate
-Dynomax Cat-back
-gutted MAF
-K&N's
-airfoil
-shiftkit
Old Nov 29, 2001 | 11:40 PM
ChevypickupTPI's Avatar
How do you do the smog removal? I would definately be interested in that. I hate all that cluttered crap.
1991 GTA
355 4Bolt Main Block
375 Horse 327 heads
Ported Intake, Air Foil, TES Headers, Full 3" Flowmaster exhuast.
Gets me where I need to be, even when I am running Late.
Old Nov 29, 2001 | 11:54 PM
poweruser_us@yahoo.com's Avatar
If you ground park in the neutral safety switch the computer does not look at the the egr sensors
BlueIroc-Z
Jun 9, 2019 03:22 AM
italiano67
Dec 11, 2016 09:21 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
