Anyone using vortec heads and new TPI intake?
Curious to see if anyone is using the vortec heads and the new TPI intake. I am planning this build up using a zz3 cam ina 355 with forged pistons...
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Still putting mine together.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC 3" Cat. back Exhaust
14.94-92.00 mph
SDPC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
'92 CAMARO RS
B4C Alt.
Stock TBI manifolds
14.94-92.00 mph
Since the topic's already here.
Can one of you guys verify for me that vortec uses egr??
Anybody have any comments about the SDPC base quality? I noticed a comment about 'slight modifications required' That true? thanks
Car: Faster
Engine: Than
Transmission: You!
vortec TPI does use EGR, you just have to use their egr kit (sold separately) www.sdpc2000.com
Probably not but it's buried so far back a tech would have to be **** to find it.
'92 CAMARO RS
B4C Alt.
Stock TBI manifolds
14.94-92.00 mph
'92 CAMARO RS
B4C Alt.
Stock TBI manifolds
14.94-92.00 mph
It is a 'vette style' egr, so I don't see why it wouldn't be approved. The quality is pretty good. Everything lines up well, all the bolt holes are straight and the threads are tight and clean. The "modifications" for me was mostly plugging the extra holes. (2 extra coolent temp type holes on the front, one near the distributor, one up front near the #1 injector) also the coil has to be reloacated. The probelms I had... the talled deck makes getting the runners on a little tougher, the old distributor hold down bolt was too long, and the distbutor hits the maifold on the driver's side it comes shaved for a larger distributor. I had to trim the bottom of my cap a little, I highly recomend you do a test fit if you get the base. Overall I am very satisfied with it, and would buy it again. I do wish I had the time and tools to port it out and fix the distributor interfearence.
-I was thinking it may be possible to pull the maifold with the runners and everything still on because you no longer have the middle two bolts. Anyone in a position to attempt this?
Car: Faster
Engine: Than
Transmission: You!
Just some info.... Brian at Scoggin-Dickey told me that the vortec base that they make flows more CFM than an aftermarket standard style TPI base (stock for Stock) with no additional porting. I have dremel tools with steel carbide bits. This is what I'll use to modify the base (porting for siamesed runners, distributor clearance if necessary, etc.) I'm also going to port the runners and upper plenum.
BitchinCamaro: great response!
Do you feel you gained the HP numbers that were claimed? I read around 375 after the heads/manifold and a cam
Whatchoo think?
I called salee chevy here in my state and basically for $1k even I can get brand new vortec heads assembled with screw in studs and springs good to .510, AND the base.
Tell me that you can spend a better grand than that
thanks!
Whatchoo think?
!thanks!
Im hoping to have my car back on the road around the first of the year as long as we dont get snow I will try to get the car to a dyno after it back from the paint room.
87gta 355 fastburn heads,slp headers,flowmaster exhaust, LT4 hot cam and a lot more
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
