throttle body coolant bypass kits
Old Jun 12, 2008 | 10:00 PM
tshack's Avatar
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
Is Any one useing the coolant bypass kits for the throttle body on thier tpi cars. They claim 12-15 hp gain. But warn not to use it during the winter. I have one I'm going to try, we get a lot of 100* + days up here in Red Bluff Ca..
Old Jun 12, 2008 | 10:51 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
Re: throttle body coolant bypass kits
the only problem youd has is when it gets down to within freezing temperatures which could cause the throttle to freeze up if theres any moisture in there, but if it just gets cold like 45 to 45* degrees and not 30 to 25* and below. you should be fine
Old Jun 14, 2008 | 06:27 AM
IROCZ4BD3's Avatar
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
You do not need to waste your $ on the kit.Just reroute the hoses to bypass the TB.Use a piece of copper tubing with 2 hose clamps to extend the one hose longer
Old Jun 15, 2008 | 10:11 PM
MedVader's Avatar
Car: 90 Formula hardtop
Engine: 5.0 TPI
I just went to the auto parts store and bought an L shaped hose for $10. Routes perfectly from the manifold to the plastic coolant valve.
Old Jun 16, 2008 | 12:11 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i just took one of the existing hoses, bent it in half and clamped it onto the other end. no flow needs to go through it. and it was FREE.
Old Jun 17, 2008 | 05:32 PM
tshack's Avatar
Car: 87 Z28
Axle/Gears: 3:43
so a few of you are bypassing the TB . did any of you notice any difference?
Was it worth it?
Old Feb 9, 2011 | 09:21 PM
CamaroIROC88350's Avatar
Was it worth it?
No, not really in terms of any noticeable gain.
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
