GM 350 H.O. Crate Motor Transplant Questions
Has anyone installed a GM 350 HO crate motor in their third gen? It's not the ZZ4, it pushes 320 HP and 380 ft/lbs. of torque. GM lists it for $2095 and does not come with the intake manifold, carb, distributor, or waterpump.
What do you guys think of this deal? I want to bolt on my TPI with the Vortec intake base. Do you guys see any problems with this setup?
Plus are all the provisions there that I need to easily transfer all the TPI and other sensors etc. onto this crate motor or will I need to modify things?
1988 L98 GTA
3.73 Posi
Polished & Ported Plenum, JET AFPR
Free Mods, Cold air Intake
Subframe Connectors, Strut Tower Brace, Lowered,
SLP 1 3/4" Stainless Headers, Edelbrock Catback, High Flow Converter,
Crane Fireball Ignition,
BF Goodrich G-Force P255/50R16's
1988 L98 GTA
3.73 Posi
My buddy runs the pre-vortec version of that engine with a TPI is his '77 Camaro with pretty good results. I am have the vortec heads, SDPC base, and slp 1 3/4 headers, everything seems to line up fine. The stock vortecs are only good to about 480 lift, so if you ever plan on changing out the cam, you will need new springs. It is a really nice basic perfromance engine and should pretty much drop right in.
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
I have the older version of it, too. It was the CC350 rated at 300hp. It's been a great base for my build-up. I pretty much used it as a short-block, ditching the heads right away.
Bob '89 Ram Air Formula 350
And until that time when death won't wait, let each man rage against his fate. (O'neill)
My car's homepage
Reader's Ride
My car's homepage
Reader's Ride
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Oh man nice head lights!
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400small block
<font face="Verdana, Arial" size="2">Originally posted by RCR:
</font>
</font>
89 Formula Firebird
Red with T-tops
5.0 305 FI
I helped put one of those in a 87 monte ss. It ran great with a 600 eledbrock and headers. You need a posi rear for this motor, it will spin through 3rd gear for 400-600 feet with ease one legger.
86 Iroc, 383 Ported and polished Sportsman II, saimesed and ported TPI, #24 svo, custom chip, Hedman longtubes 3" y-pipe 4" flowmaster dual exit, Serpentine with Hypertech Pulleys, Comp Cams roller 218 224, 1.6 crane gold rockers, Yank 9.5" 3500 torque thruster, Stage 3 Pro-Built 700R4
98 K2500, Thorley Headers, Flowmaster 50 Series w/ 3" tailpipes, Hypertech power programmer III, K&N cold air, poweraid TB spacer, 170 t-stat
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The cam is a little small cuz those are stock Vortec heads, but its a nice engine. Remember that 330 HP rating is a dyno rating, not a street rating. The street rating is probably 275 HP or so.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
317 RWHP, 418 RWTQ
Southern California
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
